Now, ya see, all it took was a post from my friend Fred and I get some luck to go my way....
I may actually have to seriously rethink my "tail setup"....but this is so hard for me to give up because, ergonomically, it just all fits in there so dang perfect!
So, anyway... I am out in the garage and I see out of all the "electrical voodoo" I have purchased over the last couple weeks and I have an extra choke that came in a two pack from Radio shack.... these are the rectangle type. (
These)
I flip through the instructions and I see that they are made to clip together in series. So I clip two of them together and coil the power cord from the centech to the starcom, closest to the starcom....and I hear significantly reduced static when I hold transmit.
I also moved the grounding point of the Centech Fuse box from the seat adjustment bracket to the negative on the battery. WAY less static on transmit. (Moving the ground I think made the most difference - I read an article about similar problems on an FJR forum and they said the FJR is designed to bleed all of it's electrical noise to the frame...they were pretty adamant about grounding accessories to the battery).
I think the key to getting completely silent may be moving to a small external antenna. I know Turbo Tom makes a special bracket mount for this (RickJ has one) and I really like it.... but if I can get "usable" noise levels with out this....I'll forgo the antenna.
While I am not completely noise free, I did at least accomplish something... I got the my Zumo hardwired and cleaned up some wiring that I wasn't happy with. It's great... the Zumo now powers up with the ignition. Used the black plug on the quartet harness. Since the Zumo has battery power also, I can use it in the parking lot when stopped, without running the bike's battery down. The Zumo senses when the engine is turned off and asks if it should stay on...otherwise, it shuts itself off in 30 seconds. Nice feature.
Anyway... I really think the Starcom at this point is way more sensitive to electrical noise than Autocom....just from what I have read....I guess I may end up switching in the future if I can't get happy.
I will be sure to check out your setup at TechSTOC next weekend,Fred. Thanks for feeling the pain with me...misery likes company...
<D>
I have been following your threads in regards to your Starcom and comm. connections Dan and I have been feeling your pain.
I know that you wanted to go in the direction of putting all the stuff under seats and fairings, and you have been having a lot of static and electronic feedback noise. I get those too. I have, I feel, solved some of it, but in a different fashion and one to consider if you wish to re-construct your setup. As you know I use a tankbag to hold all my comm. and music devices along with the Starcom itself and all the snakey wiring that goes with (though I have some ideas on minmizing that). For my music (satellite radio and mini-disc player) I have a 3.5mm plug audio cable that has a noise filter on it, and man! That baby is cyrstal clear. Got it at Crutchfield and you could use it as a audio cable adapter connection. I have also read on other threads, and have discovered for myself, that devices not powered to the bike such as battery operated devices do not pick up the bike's electronics and motors, but once you connect the device to bike power you get noise.
I would try the inline noise filter plug adapter cable I mentioned and simplify the setup as much as possible. And this is advice from a dude who don't know poop about electrical and magnetic noise fields and crap! LOL. I just feel your fustration, and my setup is working so nicely. It just don't seem fair! LOL!
See ya for TechSTOC!
