Fasten your seat belts.
Actually, it only fueled the fire. Larry Igofar had some first-hand experience with M77 not being up to the task of spline lube. I'm not sure if he personally maintained the bikes in question, and applied the M77 himself, or if he knew the owners who used it. That started a 100+ post thread on all the options available instead of M77.Do they ? If so, that solves the discussion that has been going on since Moly60 disappeared.
Over the years I've kept a good supply of Moly 60 on hand and still have one tube about half gone and one tube unopened. So, I'll be a a few years until I'm looking for a replacement, but the M77 spec doesn't seem to cut it from what I've read so far.
Hi Joe:...starting to replace brakes and rear tire, got the moly paste, but now O-rings may take too long to get here.
Big difference of the 1100 and 1300 setup. 1300 orings last a long time. The person I rep;lied to has a 1300.Well you got lucky I didn't. And at 100k miles those O-rings are overdue.
Let me see if I can find the remainder of mine and you can have them.
By the way the broken Oring was a PITA to fish out of there. It wasn't obvious it was broken without exploration
There may be an expiration date, or shelf life on the older stuff. I was told they have not produced it in the last 5-6 years, and a couple sites suggests it only has a shelf life of about 2 years.
I do not know if this is correct or not, simply repeating what I heard from a senior mechanic at a rather large Honda Service Dept.
some really nice versions of the Honda NC700's out their, sorta like a mini ST,and your still on a motorcycleHey, don't feel bad - I'm 64, and it seems that the bike gains about 20 pounds of weight every year. I own 2 STs, a 2001 ST 1100 and 2012 ST 1300. I really like them, but the weight is starting to cause me concern during low-speed maneuvering (typically when parking it, etc.).
I now find myself looking longingly at Suzuki Burgmans...
Michael
Hi Joe:
The size of the O-rings is indicated in the Honda parts catalog description - if you go look at an online parts catalog (here's a direct link to the appropriate page on Partzilla), you'll see that item 23 on that page is a 61 by 2 O-ring, and item 24 is a 50.5 by 3.5.
But, having said that, I would be very cautious about substituting an identically sized "generic" O-ring. You won't know if it is made of material designed to withstand the pressure, rotational speed, and exposure to molybdenum paste in the rear wheel. If you get an identically sized O-ring that was made for a soft-serve ice cream machine, you can be assured it will not harbour food bacteria and it will perform well at freezing temperatures... but how well it will hold up in your final drive is another question entirely.
I've ordered lots of these O-rings in the past for both my 1100 and 1300 - normally then don't take more than 1 day to arrive if they are ordered at a Honda dealer. There's not much money to be saved by online ordering due to the additional postage costs.
Michael
Although I don't think it is critical to do so, I usually apply a WEE bit of moly lubricant to the groove that the O-ring sits in, and to the outer surface of the O-ring, just to reduce wear on the O-ring.When applying the correct moly paste, should a small amount be applied to the groove UNDER each of the o-rings?
Larry, what do you recommend to lube the splines with if the honda M77 is not up to the task?There may be an expiration date, or shelf life on the older stuff. I was told they have not produced it in the last 5-6 years, and a couple sites suggests it only has a shelf life of about 2 years.
No worries, re-hashing is what we live for at ST-O!Thanks! Sorry to rehash an old subject, I wasnt here for the first go-round!
