Did you ever get the problem solved? I just picked up a 2005 gz250 with 2700 miles. Its for my daughter to learn on.*snip*
My neighbor thinks it might be an electrical component warming up and losing connection. But the bike starts right up in 3 to 5 minutes after dieing.
If it's vapor lock, how is that fixed? I'm at a loss here.
Woof.
Don't add a fuel filter.
Most bikes will run if you address JUST ONE circuit in the carb, the pilot circuit. The only two you really need to address are the pilot screw (it's on the bottom, marked part 26 on parts diagrams) and the pilot jet. I dont' know the setting of the pilot screw, but I expect it will be 1.5 turns or 2.5 turns out. (I'm a GS head, not a GZ head)
3-5 minutes of running can be charging system, or pilot circuit. Vapor lock, is kinda not a thing on bikes. Vapor lock was the fuel boiling in fuel lines and causing havoc under the hood of the car. Starvation can happen, but that's usually limited to long runs at WOT, where there isn't enough vacuum signal to keep the petcock open.
The floats seemed to be set right. I did not test if it stopped the flow of gas. I did wipe the needle seat smooth.
There is a hanging idle. I played around with the mixture screw a little. It was out almost 4 turns. Previous owner was trying to get it running without cleaning the carb. Probably messed with the adjustment.
I screwed it in and then out 2 turns. Adjusted it to get a smooth idle. I need a better short screwdriver for that.
I forgot to try it without the air filter. The air filter did smell like gas the other day, but it was not wet.
There was a little too much oil so I corrected that. The bike runs a little better now. But the idle will still slow down and eventually die, unless I feather the throttle. The hanging idle is somewhat better but still there.
My next step is to replace the vacuum lines.
If that does not work, I will remove and inspect the boot. I sprayed carb cleaner on it while running and there was no change.
Has anyone replaced the carb with an upgrade? They look to be $40 and up. I could buy a new carb for the price of rebuild kit and diaphragm kit.
I watched a YouTube where the guy did that and it fixed his issues. He claimed the bike ran better with more power. But he is not very clear on the upgraded carb info.
It looks identical to oem but has a hand choke and an electrical throttle position sensor that is not needed.
You don't need a perfect seal with the float valve, just good enough that the carb doesn't flood while running. That's why we have vacuum petcocks. Speaking of which, the vacuum levels these bikes work at, as long as it's "there" it's going to be ok.
Your pilot screw setting is probally slightly lean. For the later carbs with the finer pilot screw threads, 2.5-2.75 seems to be the right starting point.
You're got a leaking carb boot. Most probally, it's JUST the o-ring under it, those things have a lifetime that's around 10 years, and they get glass hard in the end. Go to the local hardware store, and get a replacement o-ring, it'll be less than $1. If you want a replacement part that will last forever, you can spend $5-10 on a silicone one.. but I've never bothered.
"Other carbs" is opening a bag of worms you really, really, don't wanna open up.
Keep in mind, this is a CV carb, and it will only perform correctly when it's got the airbox on it, with the air filter in it.
