Has anyone run a 1” lower rear shock and Darkside together on ST1300 ?
PhotoDoctor
Tampa Mike
Tampa, FL
ST1100/ST1300/Norton
Has anyone actually run a rear darkside 205/50/17 along with a 1” lower rear shock? I’ve seen both options independently on the ST1300 but not both on the same bike………..
Camarillo, Ca
2006 ST1300A
002552
I do not think that would work. I run a 205/50/17 car tire in the back. It is a tight fit so there would be no room to lower the rear suspension of the bike. If you did the outer edges might rub on the inside top of the fender. I run stock suspension and have had no rubbing in the last 110k darkside miles....
Minnesota
2012 ST 1300
007798
8560
You do not want to lower the rear suspension without a corresponding drop in the front. Shifting the weight to the rear tire makes the front end light and squirrelly, and you really won't be happy behind a semi.
The CT doesn't raise the rear of the bike at 205-50-17. As for clearance issues, tire profiles vary widely. Some are squared at the shoulder and others much rounder. Rounder is better.
010688
The normal effect of lowering the rear by itself is to effectively increase rake and trail which slows steering.
PhotoDoctor
PhotoDoctor
Tampa Mike
Tampa, FL
Stew1300 - wow that's a lot of lowering 2 1/4" , I'll have to check out the Wilbur shocks this is the first I've heard of them. What are you using for a rear tire?
On my 1300 I have a- Bridgestone run Flat Drive Gaurd 205/50/17 - with the stock shock. (It goes up on the center stand super easy )
Green Bay WI
8256
sorry I'm late, Tire is Hankook 205/50-17
The Wilbur shock is expensive, I got mine 7-8 years ago from a ST1300 guy who traded his bike on a Harley, he
also had the side stand cut and rewelded( looks orig), hard to get the 1300 up on the center stand though, I use a piece of 2 x 6 with a 1 x added .
Green Bay WI
8256
Mike, I'm across the state from you in Wabasso for the winter, I've stayed here for the past 5 years.
PhotoDoctor
PhotoDoctor
Tampa Mike
Tampa, FL
Stew - thanks for that info. I might like to come over and take a look at that.
wjbertrand
Ventura Highway
Ventura, CA
The ST (1100 or 1300) is not blessed with a lot of ground clearance. Unless you're a real tip-toer around corners, you run a high risk of grounding hard parts which can lever tires up and cause a crash. To me cornering is the most fun aspect of riding a motorcycle, it'd be a sin to reduce that capability.
Richmond, VA
'01 & '96 ST1100s
9007
On my 1100, the only thing that has touched the road is the tips of my boots.
Freaked me out the first time it happened; now I know to expect it.
