Where did you get the flasher and does it have the automotive 1/4 inch prongs or the flat micro three
Recently I replaces the rear indicators with some amber LEDs from superbrightleds - would be handy if a flashback LED failed since the original bulbs wouldn't be any good with the clear lenses.
Are you talking about swapping an amber LED from the rear turn signal to the front in the eent of a switchback failure?
so if a switchback LED failed I could borrow one of the rear orange LEDs to use in the front and put a bulb in the rear temporarily.
I assume then that you put 7443 LEDs in the rear instead of 7440s? Otherwise you'd have a turn signal but no position light. Not a big deal in a temporary situation though.
I did think of buying 2 more flashback LEDs but decided the cost wasn't worth it, especially when the current flashback LEDs in the front could run for years without failure.
The MCC brand cruise control needs incandescent brake lights in order to work. Just keep that in mind. My ST came already equipped with the GL switch cruise control mod. Don't know if that works with the LEDs. I haven't got around to trying it yet.
I did just stick LED headlights in, however!
FYI
You could put 7443s in back and they would work fine. Thd low wattage wires are not present on the turn signal sockets.
The white side of my flashbacks failed in the front turn signals. I moved those to the back. Brightest rear turn signals I have seen yet.
I hadn't thought of that aspect!
Next time I buy some switch backs I am mounting them in a mirror housing and letting them burn-in for hours, maybe even set the holder in a slightly warmed oven to simulate a hot summer day in the sun. Do this soon as they arrive so I can promptly do the refund thing if they die.
My bike has stock lighting which works awesome.
Not very impressed with LED lighting
Also brighter than stock and I think with a greater difference when using the brakes. I went with warm white because red LEDs wouldn't be legal for illuminating the license plate and with cool white there would be less of the light making its way through the red tail light lens.
My tail/brake LEDs are red. I chose red because there hasn't been much reason to ride in darkness and I wanted the tail lights as bright as possible red LEDs being the most efficient color behind the red lens. I've seen the LED bolts and thought about them but more wires... An LED strip inside the housing would be very trick. There will have to be a dedicated buss for all the extra LED lights!
I'll try the red version of Kiwi's brake/tail light choice. It will light up the lens better but I don't know if the end LEDs will match the LED/lens combo of my current light.
