So Honda Switch deals with the 'circuit separation' properly?Happy to report that I've been successful with installing both the hazard switch and the light switch. Both function as intended.
Yes it does! no diodes required. Easy to wire in. I probably could have tapped into the bikes own flasher unit instead of installing a separate one.So Honda Switch deals with the 'circuit separation' properly?
You have to cut a 'fresh' hole on US models.Not being familiar with the 1100 (despite the many threads I've read) did your hazard and driving light switches replace other switches? Heated grips or something? It's a clean install regardless.
Thank you. This is the location for the police models. As Uncil Phil mentioned, I had to cut a hole, the bezel and switches are available through partzilla. I had this pocket fairing on my 97, I had adapted switches from Asia. For this bike (2002). I wanted it to look more Honda.Not being familiar with the 1100 (despite the many threads I've read) did your hazard and driving light switches replace other switches? Heated grips or something? It's a clean install regardless.
Neat installation indeed, but...I wanted the hazard flashers to work without the ignition key (hot wired).
Thanks Unk. This clears up a few questions I was about to ask. I've only used it twice (now that I think of it) but the hazard switch is a welcome bit on the 1300. I wish we'd got the FTP switch as well. Using the starter button is an inelegant alternative.In the USA, the 'hazards' work depending on how you wire them since our models did not come with hazards but the European models did.
I have mine wired with a fused connection directly to the battery, diodes to stop the flow, another flasher and #5 on the police switch to fire them.
Kiltman's installation used the European switch and bezel.
Rather get the ST1100 (or the non-ABS ST1300) LH switch-pod where you can operate that PASS conveniently with your index finger...I wish we'd got the FTP switch as well. Using the starter button is an inelegant alternative.
IIRC did the UK police bikes utilize a second ignition lock/key on the LHS infill enabling to remove the original ignition key while engine and flashers kept going...I think that I would put another switch in-line somewhere out of sight to disable the power source to them if I felt the need to do so.
