Okay, so here's one I've been thinking about.
I live in Nova Scotia. Cool temperatures. Our car (and my motorbike) get better MPG in the summer than fall/(winter)/spring.
So, cold air is more dense, containing more oxygen, but still it seems that warm air will aid the explosiveness of the air/fuel mixture and hence require less fuel, resulting in better fuel efficiency.
Sure, denser air means greater drag, but even in the city where air drag is nominal, the MPG goes way down in cold weather.
So, I was thinking of a crazy idea of putting a heater inside the airbox, with thermostat and controller, to heat the air before it enters the engine in temperatures below 15 to 20 degrees Celsius.
Does anyone have any thoughts...? I've done some reading. Sure, colder oil means more viscosity means greater drag. But, the engine gets warm to operating temp pretty quickly and maintains the same operating temperature whether ambient is 5 degrees or 25 degrees Celsius. So I don't buy this "extra drag" hypothesis.
Also, if tire pressure is adjusted correctly, there would presumably be less friction/drag from tire surface to road surface. So I don't buy this hypothesis either.
If indeed a warmer air intake helps fuel efficiency, it seems like a heated air filter would be awesome!
