Will the 1300 stand up to a 40W heated jacket running off it???? I don't want to "fry" any part of my PAN.
Here is my experience. I've installed Warm'n Safe heated gear. I use these all at the same time, because I'm riding two-up: Two heated jacket liners (90watts each), two heated pair of gloves, one pair of heated socks and, rarely, a pair of heated pants. I had to make sure they were wired to the battery, not to a fuse block. Wired to the battery I've had zero issues. Wired through a fuse block caused over-heating issues at the connections on the fuse block.Will the 1300 stand up to a 40W heated jacket running off it???? I don't want to "fry" any part of my PAN.
What kind of fuseblock? I had problems like that with a Centech AP2 but switched to a easternbeaver PC8 and have had zero problems with it.Here is my experience. I've installed Warm'n Safe heated gear. I use these all at the same time, because I'm riding two-up: Two heated jacket liners (90watts each), two heated pair of gloves, one pair of heated socks and, rarely, a pair of heated pants. I had to make sure they were wired to the battery, not to a fuse block. Wired to the battery I've had zero issues. Wired through a fuse block caused over-heating issues at the connections on the fuse block.
It won't even notice.Will the 1300 stand up to a 40W heated jacket running off it???? I don't want to "fry" any part of my PAN.
I run a 90 watt jacket and heated gloves from first gear with no problems at all.Will the 1300 stand up to a 40W heated jacket running off it???? I don't want to "fry" any part of my PAN.
I used Powerlet's Termin-8.What kind of fuseblock? I had problems like that with a Centech AP2 but switched to a easternbeaver PC8 and have had zero problems with it.
