Does any one want to help me do my 16,000 mile maintenance? When I say "help", I mean do it while I watch
Barring that, how much do you think it would cost at a shop?
Im in the north central part (Grand Rapids, Mn) so if Im closer than some others, let me know and we/I can give it some attention.Where in Minnesota? Per above, pretty simple maintenance involved.........good luck.....ff
St. PaulWhere in Minnesota? Per above, pretty simple maintenance involved.........good luck.....ff
I think I like this answer best. I have about 16,300 now and I changed the oil and filter already this Spring. I had the clutch and brake fluid changed last year. I'll try to make the tech event this year depending on my schedule. Thanks ALL for the replies.Since almost ALL of us hardly check the valves until like....30K....50K......sometime, all you need to do is check the nuts/bolts and make sure to change the fluids. Oil, filter, rear shaft fluid. I waited on the brake/clutch fluids until 30K. Do you do your own oil changes? Easy-peezy. That's about it.......others will surely HAVE their opinion. This is just mine...my '06 has just turned 60K...and running like a Gem!
where is the tech event being held in Wisconsin.
Get yourself a shop manual.Does any one want to help me do my 16,000 mile maintenance? When I say "help", I mean do it while I watch
