Anyone remove their ignition switch assembly? I tried almost everything and I still can't get the switch off the bike.
Two bolts hold the switch in place. They look like 6 mm allen heads: a 6 mm allen wrench grabs in the clockwise direction, but when turned counterclockwise, the wrench just slips. The parts fische identifies these bolts as, "bolts, one-way" which makes sense for the ignition switch, but how do I remove them? I've attached pictures of the bolts and switch underside. On the closeup picture you can see that I tried a bolt remover (unsucessfully). No mention in the shop manual of special screws or of tools needed to remove them.
I also removed the electrical assembly plastic cover; it had two #10 security torx screws holding it on. Still can't remove the electrical assembly though, I can't grab the assembly.
Anyone done this job?
