Ignorance is bliss...
Jerbear
'95 ST1100, '02 919
Not when it comes to tires ;)
So long story short, had new set of tires installed couple years ago by one of the more reputable dealers around.
Due to some knee issues didn't ride much since that time. Somewhat recently came back to riding the ST and noticed that the bike does not feel as solid as it once did.
I checked and re-checked, tire pressure, wheel bearings and the other usual suspects. I didn't notice anything unusual at that time.
Last night when I found the coolant crust on my radiator (different post), I took a closer look at the front tire. Big flat spot in the center and a lot of uneven wear on the outside radii.
What can cause such weird wear on the tread? It is a Bridgestone Battlax T31 with maybe 2-3K on it.
And now you can also point fingers and laugh at me but only now did I notice that the tire was installed backward. Talk about feeling stupid🥺 and angry at yourself🤬
I got that same ridge on the front tire with both a T31 and a Roadsmart 3 between 3 to 5K, seems to be related to the crowning of the pavement, I was told.
Flat spot in the center - ala chicken stripe - is due to riding upright. This happens from doing mostly slab riding and not much canyon carving.
Edit. Not sure if its the angle of the photo, but is the front wheel centered in the fender? We had a post recently in which the spacers were flipped, making the wheel not centered.
I'm trying to imagine what the less reputable dealers in your area are capable of.
Did you take the bike in, or remove the wheel and take it in? Either way I'd take it back in and ask them to remount it in the proper orientation. If you take the bike in, make sure they mount the wheel properly, hard to tell anything from your picture, but the alignment of the tire to the fender seems kinda weird. Maybe just camera angle.
The raised flat center ridge is the result of the edges of the harder rubber compound. If you ride the interstate more, and keep the pressure up, it will get used.
The greater wear on the left side is theoretically due to left turns being longer than right turns in the US, but I wonder why cloverleaf ramps don't compensate.
