Newby here. Does the fuel pump need to be continuously running? If not, how does the fuel get through the filter to the carbs?
yep, that's consistent with these comments earlierSure enough AI st110 (No #5 above) is correct,
I was of the impression that the pump stopped due to back pressure in the fuel line from vac switch or floats in the carbs cutting off fuel flow.
I was wrong.
With the pipe from the tank disconnected the pump runs & shuts off when ignition switched on, then runs continuously when engine starts.
Fuel pump relay get turned on again when it sees engine rpm. Runs until it's turned off by the ignition switch or the tip over sensor.
The fuel pump relay energizes from pulses coming from the ignition module, so if its generating pulses the fuel pump is pumping.
That would be highly unusual… a first in my 24+ years on the forums. Would love to see a picture of it. TIAthe fuel pipe of the top of the tank, there was a small pin hole in the pipe
Sorry John, I think I didn't explain that quite right.That would be highly unusual… a first in my 24+ years on the forums. Would love to see a picture of it. TIA
Do you have an 1100? The 1300 has FI.If not, how does the fuel get through the filter to the carbs?
