Innovv K6
If you don't care about the parking sensor scenario... just hook the black to negative and the red AND yellow to switched power. That should not pull any power at all.
Regarding the battery drain issue.....
I have the K3. The software / hardware has a feature to address this. I assume that the same system was subsequently employed on the later units. The recording unit needs to be able to save its recording to the SD card when the ignition is turned off, so the unit needs to have two power sources - one from the ignition, and a stay-alive power supply from the battery.
Once the appropriate files have been saved, the unit disconnects itself from the battery - like an electronic relay.
I didn't want to trust this when I installed it, so I put in a connector into the power cable from the battery so that I could unplug it when it was standing in the garage. Its under the seat, so by the time I've lifted the seat, the K3 has shut itself down anyway. I use the same power connector for charging the battery.
I did test this shut down procedure of the K3 this autumn. Left the bike untouched in the garage for a month without disconnecting it from the battery. The bike started fine.
But there is a problem. It seems that if you turn on the ignition and then off before the K3 has started up properly, then it does not shut down properly, and it will drain the battery within a day. But if the button console has indicated that it is recording video before I turn off the ignition, it seems to be fine.
But if I am away on tour, I always disconnect that connector to the battery. Once bitten .........
A simple switch somewhere handy would be useful, but I am aware that the switch would need to be connected directly to the battery, so prefer to keep that cable short and well protected.
I did like the K5 when I bought the K3 - but the size of that main camera put me off.
The power inverter that comes w/K6 has somewhat of a battery monitor light -
Only problem with that is that your last video clip(s) may be corrupted as the system did not do a proper shut down. Might not be an issue if you keep your clips short, however.
I had a dash system in my car that would shut off if the battery got below a predetermined level. Innovv should implement something similar.
Lane splitting, particularly at a bit of speed, looks just plain nuts to me. And that just about what would happen around here if we were to do it.
It looks just plain nuts because it is just plain nuts.
I did some early morning dark riding to see the quality. The sound is just loud wind noise so I'll dial that down in the settings I think.
Front in a residential neighborhood.
Rear
Freeway Front
Freeway Rear
My :twocents1:, FWIW some nice resolution from the front cam but some interesting light halos from the rear cam. Image stabilization is great.
2nd observation, seems awfully quiet in DFW for a Saturday morning :shrug1:
Thanks for sharing!
Thanks for sharing!
It was dark and cloudy so maybe some atmospheric effects beats me.
I wanted to see the video in dark conditions, seems adequate. Tomorrow I'll get some in sunlight to see the best conditions.
I run all my errands early around here if I can.
Amazon has a 16 or 20 dollar coupon on these, depending on the seller.
