Sidekick
Save Ukraine Stop War!
For me, the condition of the length of the pin was never an issue. They always cleaned up well. I disagree with Dave about installing them dry. I know they arrive from the factory without anything on the pin, or on the backing plates, but we get a lot of muck, salt and grime chucked up off the road in the Uk. For me it is rust prevention rather then lubricant. Without it, they rust in very little time.
The issue with the pad pin has always been the state of the hex socket. Tightened to spec at 18Nm, they can become too tight to remove without affecting the soft metal. I learned that lesson the hard way, twice, on my ST1100 when they required major surgery to get out when the socket rounded off. The first sign of any movement on removing, I'd throw the pin away. That usually happened after 3-4 removals.
Whether those pins had an O ring, I cannot remember. I know now that they should have had one. Certainly, without, the narrow end is free to oscillate and I suppose this may result in the pin being harder to remove ? Both of my 1100s were second hand and I never had a Honda manual for these, so I doubt that I would have checked for an O ring if they were missing.
I don't have that problem on the A9. I modified a front pad pin to fit the rear caliper - and they do need modification !
Do you mean that you would also use some grease between the backing plates and the pads, If yes, what kind?
