Reminds me of this thread I wrote about 3 years ago! (and my tank did not even come close to looking like that)
Have you ever looked inside of your gas tank?
That's a pretty big open ended question. Lot's of additives, lots of reasons they get put in there.Does anyone know if fuel additives cause problems?
Fuel is oxygenated. Add the moisture that ethanol attracts, and a full tank of fuel will rust faster than an empty one. The photo below is of a tank that was full for 1 year with e10. Its actually a 15 year old generator, but never saw ethanol until last year, and was still in great shape until then. 14 years without ethanol, and it stayed shiny new; 1 year with, and this is the result. You decide. I live in a very humid area, so plenty of moisture to be drawn in. I make a decent living replacing fuel tanks, lines, and pumps that have rusted on the inside.Even though it looks like rust from your pictures I don't think that it is. You would have needed that tank to be empty for quite some time as well as a lot of moisture present. If you went and operated the bike until it ran out of fuel there would still be some left on the bottom of the tank. The rust would form everywhere except the areas still covered by the fuel, i.e. bottom of the tank.
Shazzam! Well I guess you must be glad that you didn't listen to me and simply ordered a replacement fuel pump off of eBay. Be interesting to see the inside of that filter.
The bike is an '05 that I bought it in August and it only had 7800 miles on it. So yeah, it had to have sat for quite a while at some point in its life.Even though it looks like rust from your pictures I don't think that it is. You would have needed that tank to be empty for quite some time as well as a lot of moisture present.
Could be it was larger particles early on when it first started to rust... then it sat for a few years and adding gas to it recently due to your purchase and riding may have caused it to appear as it does...We'll see. At this point, I suspect it may be combination of both dirt and rust. The way that gasoline wet stuff came off the pump, turned to mush in my fingers and broke apart into silt sized particles makes me almost certain that it's dirt (mud if you will). In my experience, rust particles are much bigger and certainly aren't going to disassociate into very fine particles from just pinching it between the fingers.
Since I found no evidence of dirt in the upper tank, I've got to concede to those whose opinions were on the side of rust in the lower tank. The thing that still weirds me out is the nature of the "rust"... the way it just crumbles into very fine, silt sized particles. Just like mud. It's almost as if the stuff is a precipitate. Can e10 cause this???Your pics & description of the substance you've encountered appears to be an exact match for what I found in the tank of a used Jeep Cherokee (one of our fleet vehicles) that I bought a few years back. The vehicle had been out of service for a little over a year when I bought it. I had to put a new fuel pump on it due to the "gunk" that was present. I know for certain that e10 was used in it 99% of the time.
Thanks for mentioning this. It's reassuring. Maybe one of these days I'll actually have a running, reliable, LD touring bike.I also had to replace the fuel sending unit.....when I touched it, it also turned to dust. Having said that, after replacing the tank, pump, sending unit & filter, the Jeep hasn't given a minutes trouble since.
snip
So, should I just sand off the little bit of surface rust or leave it alone? Should the spot be treated with anything to stabilize it?
Anything else I should do?
So what do you do if you can't avoid it? I just looked at this website:You guys are making it sound like this is an uncommon thing. Add ethanol, let it sit for several months, and this is the result.
