I am now in a slight situation as I have no key for my Honda ST1300 and not sure how I can get another key cut and programmed to the bike any ideas would be grateful thanks
My guess is that a new BMW key from the factory would cost more than a used ST1300.I don’t know if Honda can do this but with the BMW you can go to the dealer and they order the key from the factory.
Craig, You will have to go to take your bike to your local Honda dealer and he will be able to programme a new key for you. Might be worth giving them a ring first.
On at least some other Hondas, the key number is stamped on the ignition switch barrel.
Keys have been found minus the chip.Is that in Oz ? Do they have HISS on the bikes over there ? I seem to think that they do.
I have read once that it is possible, but I have not seen anyone confirm it.
The key is programmed to the ECU, and while it is easy to program a new key if you have an existing working key, it is extremely difficult to get a key without an original.
The idea is to make a stolen bike difficult to sell on.
A solution would be to find the same spec bike being broken, that has working keys. Match the model number of the ECM with your own and buy the ECM with the keys. You still need a key cut to fit the ignition pannier and fairing pocket.
The HISS chip can be removed from one key and put into another. In fact the bike will start with the chip held against a non-chipped key.
The problem is a lot easier to solve if they don't have HISS.
Much easier to find the lost key. Phrases like 'Where were you when you remember having the key". Are tried and tested methods.
I'm finding it hard to imagine a scenario where my kids would have my bike keys in the first place. Unless they are teething. Then anything that fits in a mouth will do.
Can you explain a bit more? I'm not familiar with the HISS system. I would expect that getting the chip out of the key is an involved process - not something easily or accidentally done. What happened? From what the guys said above, you will still face a large task (or bill) to get the bike running again.Keys have been found minus the chip.
Was just over $100 for the key. Before I picked up the new key I found the lost key in my desk drawer.My guess is that a new BMW key from the factory would cost more than a used ST1300.
Is the chip in a fob and not actually part of the key?Keys have been found minus the chip.
Yes, somebody posted they sent their ECU off to someone in the UK and they sent it back with working HISS keys.The Honda mothership must have a factory procedure in which a new ECM is instructed to recognise a new chip however.
From the owner's manual:
