First off I appologize for the length of this post.
I have been doing some research for the purchase of an Autocom system (Super Pro AVi) to use for bike-bike, and I noticed lots of useful information on this forum regarding the Kenwood radio's for this set-up.
I, like many here, don't want to pay $300 for the AT2. I noticed lots of confused and unhappy buyers of various Kenwood products, so I thought I'd share what I've found out
First off, the two units from Autocom are the following Kenwood products:
Autocom................. Kenwood equivalent................. Autocom Direct Power supply
AT-2........................TK-3200 L (2 watts).................... 1402
AT-4........................TK-3202 L (4 watts).....................not recommended for 4 watt unit
TK-3101...................TK-3101 (2 watts).......................102P
Most who want to power the radio directly from the AVi will want the AT2. The TK-3101 is still a great option (if you can find one). The advantage is that the user can program the CTCSS squelch codes (or Quiet Talk as Kenwood calls it) "on the fly" without the need for programming cables or computers.
Also the 3101 generally comes programmed with the FRS/GMRS frequencies which most will want if they plan to communicate with other bikers with various different radios. The biggest disadvantage is that it doesn't come with a lithium battery, and therfore has a much shorter battery life if not powered by the bike/Autocom.
Sounds simple? NOT QUITE!!!!
Here's the main issues:
Frequencies:
Kenwood custom programs the AT-2 (and 4) to the FRS/GMRS channels. These are the same channels that the 1301 came programed with from the factory. Frequencies 1-7 are the same as all FRS radios, and 1-15 are the same as the more powerful GMRS sold by electronics stores.
Here's the Autocom frequency chart: http://www.autocomamerica.com/files/AT2-AT4_Frequencies.pdf
These are the frequencies that you want to have programed into your Kenwood Radio
Models: This is where the problems start.
TK-3101
-also referred to as FreeTalk XL
-old unit which has been replaced by AT-2
-comes factory programmed with the correct frequencies. However, this is a "programmable" radio. This means that with the aid of a computer running the proper software and the correct programing cable, the frequencies can be changed to any in the spectrum which the radio has been designed for.
this means that if you buy one used it may have been re-programmed to the wrong frequencies and you will have to "re-program" it again to return it to FRS/GMRS compatibility.
-The cable is KPG-22 (serial version with DB-9 connector)
-The software is KPG-48D. This is easily found for free on the internet. Note that it is DOS software which must be run on a DOS machine (not a windows machine in a DOS window!)
-the battery for this radio is KNB-14 (NiCd) and the stubby antenna is KRA-17M
-CTCSS may be programmed using only the radio's controlls (cumbersome but "do-able") It is these codes that prevent unwanted reception on the selected channel. This is important on the FRS frequencies, as there are lots of unwanted transmittions. All radios in the group must be set to the same Code. Autocom programmes the AT-2 to code 00 which means no code.
this is fine except you will pick up lots of noise and won't be able to communicate back to any one with a code set!!
TK-3200 -THis is a bit more tricky. Kenwood makes many versions of this radio (many of which you don't want!)
First the nomenclature:
L = Lithium Battery (good)
U = UHF (good)
P = Protalk (very bad)
K = 2 channel
K2= 8 channel
K3= 15 channel
-kenwood makes 2 basic versions of this radio
-Protalk (TK-3200 LUP, TK3200 L-U15P) Sometimes referred to as "MPD" chassis
-NOT computer programable
-comes already programed with a table of 56 frequencies which the user may select from (NONE OF WHICH ARE FRS/GMRS)
-CAN'T BE PROGRAMMED TO FRS/GMRS
-Stay away from these if you want to talk to your buddies!
-usually say "protalk" on front cover just under speaker grill
-CTCSS are user programable without computer
-TK-3200L (NON PROTALK VERSION) sometimes referred to as "LMR" chassis
-can be computer programmed to the FRS/GMRS frequencies
you will need the correct windows software KPG-88D. I believe you will need Version 2
you will also the correct cable. I believe this must be a USB cable and I'm not sure of the part number.
-CTCSS codes must be programed with computer and cable
-these radios can usually be identified by the words TK-3200 (instead of Protalk) on the front cover
- The battery is KNB-45L, and the Stubby antenna is KRA-17
-THIS IS THE ONE YOU WANT
CHANNEL SPACING
Most of these radios can be programmed (with a computer) to WIDE (25 kHz) or NARROW (12.5 kHz) channel spacing. All radios must be set on the same setting to communicate. THis can come into play with FRS radios which I believe are all NARROW, but I'm not sure.
So When you buy one of these radios, make sure it doesn't have a "P" or PROTALK in the name or on the front grill. You must get the shop to program it to the FRS/GMRS frequencies. If you know any of your buddies use QUIET TALK (CTCSS) privacy codes, have these programmed in, otherwise leave them off.
Make sure the CHANNEL SPACING is set where you want it. THis could be an issue as your buddies with TK-3101's may have a different setting from your buddies with cheaper FRS/GMRS radios! Best get a cable and software so you can change things later!.
***Interesting info: The 1402 12 volt adapter is designed for the UK model 3201 which is a .5 watt unit. Also the 102P is designed for the UK 3101 which is also a .5 watt unit. The autocom can apparently handle the current draw of a 2 watt transmitter, but there are no guarantees from Autocom. 4 watts is definitely out!
I would greatly apprediate hearing from anyone who has actually purchased a TK-3200L and has experience using it. I would especially like to know which cable they use to program it, and which software, as well as where to get it!
Here's a link to someone who actually knows something about this and sells a TK-3200 radio which should work!!!
http://www.sporttouring.ca/collections/bike-to-bike
Frequencies:
TK-3101
U = UHF (good)
K = 2 channel
K2= 8 channel
K3= 15 channel
CHANNEL SPACING
