The latest scam hitting the shelves, improperly chipped SD cards.
For instance: selling 512gb cards that are really only 16 gb (more or less)
Sellers are hitting Amazon, eBay and Wish with these cards. Have not heard of any in BM stores, but I'm sure it will at somepoint.
The memory controller on these cards has been programmed to think it is and has 512gb of available memory to use.
If you format the card, if you quick format, full format, on any device, it will look like it's a fully available 512gb card, because the chips controller really thinks it is.
The directory structure will hold 512gb worth of files it thinks it has.
In reality, the memory chips aren't there and the data (once the chips are full) is getting dumped into null space.
If you think buying a name brand helps, it may not. The scammers are screenprinting the memory cards to look just like the real name-brand ones.
Use a program like h2testw to test the actual memory.
Also, WARNING! If you buy a multi gig card and you have a usb 2.0 reader, it may take awhile. Just be prepared.
