SteveST1300
Vendor
Re: LED strip for turn signals
Nocely donr Byron Dean that looks like the best way to go.
Yes, that looks like a great job Byron.
Probably just being dense, but I'm not picturing how to do something like this with my connector. Here's a picture of a broken one and the wires I need to access.
I don't like to splice into any of the factory wiring because it is so small. Instead I like to create a plug and play connector setup. Using connectors like found here.
<snip>
Soldering would be best I would think.
If it's a high vibration area where the wires would be subject to moving quite a bit and you can get a good solid crimp. Do that.
Soldering locks the wires down and forces the vibration and movement to be taken up by the strands right at it's edge. When you crimp, the individual strands can still move just a fraction back and forth and absorb this stress better. On everything.. unless it is a low voltage connection... try to crimp.
I always insisted that techs carry a ratcheting style crimper, that way it helped ensure the crimp was full press since they don't release till you go through the whole cycle.
Just for clarification, have you already fixed this connection or are you thinking of tapping in here?
Certainly not fixed, but my mirror is flashing. Yes, need to do it properly.
1100 Byron.
On a situation like that when you are doing a permananet mod and don't want to cut the factory wiring, I prefer an inline splice.
Strip about 3/8" of insulation off a section of the original wire, but don't cut through, wrap your new wire around and solder. Insulate with some good electrical tape.
To strip the insulation, use your wire strippers to make two cuts through the insulation 3/8" apart. Use a razor knife to shave off a bit of the insulation till you get to bare wire. Then peel off the remainder.
Well I just revisited my 'just jam the wire into the female end and then push the connector together' plan. Working for the time being.
Still works fine a couple years later (just noticed that I started this thread). Never needed to do it properly.
Thanks. Now just need to decide on how I should tap into them.
Why do ppl insist on using old school methods when a posilock connection is as simple as a twist of a cap? Especially with the limited amount of wire available from mother Honda.
