Left headlight led issue
Kearns, Utah
Hello everyone, I'm having an issue with my 2005 ST 1300, I went to change out all the headlights and marker lights to LEDs this last weekend, my left headlight has blown twice in the past one year. I replace both headlights with LED in the right one works awesome, the left-hand will not light up. Flipping to high beam and low beam makes no difference, but the high beam indicator is bright on high beam, and is dim on low beam. Does anybody know about this issue and how I can fix it. Thank you
jeep4465
Kearns, Utah
Yes, I've tried swapping the right one and the same issue. I even have a brand new OEM headlight, and that doesn't light up on the left side, so I'm assuming that the light isn't bad. I can see no damage to the wires. Still don't understand why high beam indicator glows dimly on low beam.
Here is a pic of the led headlights I put in.Capture+_2018-01-29-02-16-29.jpg
Nashcat
Theta TN
2015 Versys 1000LT
8591
Anytime I've seen an issue with dash indicators acting weird, it's always been a ground wire problem in one on the connectors. I've fixed 3 with the problem, including my own.
One is the 26? Pin connector, behind the upper left cowl. The other is the yellow multi connector under the front cowl, above the right headlight. Here's a pic of the yellow connector I repaired, just a couple of weeks ago, on Seawalker's bike. You can see the connector that was hot. There are several threads describing the fix.
Ride Safe
010688
Ride Safe
+ 1 on all of that.
You might also fashion a jumper wire and insert one bare end into the side of the left headlight connector with the green wire and touch the other end to the frame nearby and see if the LH bulb lights and the high beam indicator returns to normal. The LH bulb connector often develops high resistance thus overheating and damaging the yellow buss and 24 pin connector mentioned by John.
Rochester, NY
2008 ST1300
8441
Checking ground is a good idea, but also I believe the left headlight is powered through relays whereas the right one is directly from the switch.
Does high beam work? The run separate relays under the left side cover... Possible one is loose or failing?
Hampshire, UK
+1 on the poor earth here. I used to have an FJ1200 that did odd things sometimes when the inticators were used, turned out to be the earth from the front pilot light.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
You could always hook up a SDC Headlight modulator and run both headlights off the right side! :rolleyes:
Camarillo, Ca
2006 ST1300A
002552
here is the basic schematic of the light system on the ST1300.
If the left lamp ground is open then that would explain why your hi beam indicator would be dim on low beam and no left lamp.
check all the green wires that go to ground.
North Plainfield, NJ
'06 ST1300A
A poor connection to chassis ground at the left-hand headlamp will cause the high-beam indicator to light up.
Take a look at this schematic I made when I was experiencing a similar problem with my '06 ST1300/A. In my case the ground conductor had overheated, probably due to poor electrical contacts at the headlamp connector.
010688
I also had the identical problem as the OP some years ago and fixed it with a dedicated ground from the LH headlight connector to the threaded bolt hole found on the left side of the frame behind the head stock.
Dutton
ST-1300a
GoodDay All. I have the left H/lamp out issue. ( Right OK ) I found the 10a fuse blown. RE-fused. Both H/lamps work. I suspect the left will die in the first few Hours of riding. I plan to take Dave's tac and hard wire a ground. Thank's to Dave and Anna's Dad.
F
