bdalameda
PaleoCyclist
Globalstar does not use cellular for direct communications with the device. They use cellular and even wired land service between the sattelite receiving stations and the emergency response center. When you send a message via your SPOT it is relayed from the satellite to a ground station and from there it uses either cellular or land line to the response center. Iridium does this differently. Not sure how how much difference this could make.Are you sure about the use of cellular data and difference in coverage? I could not find any corroboration that Spot uses cellular networks at all. When prompted the tracker device sends GPS location or text data up to a network of low earth orbit satellites which then relay that data directly via downlink to Spot's monitoring facilities. If the Spot monitoring facility is not "seen" by the responding satellite the data is relayed to a satellite that can downlink directly to the monitoring facility. Spot uses the same GlobalStar 48 low earth orbit satellite system for GPS location that InReach uses then uses cellular or land line to notify the emergency or routine contacts the Spot user has listed in his/her account. Presumably these contacts are going to be inside of reliable cellular or land line networks which is the only part of the system that may use cellular networks.
I found this:
Globalstar Overview
The following provides an overview of the Globalstar network.
Satellite Network
The Globalstar network consists of 40 ground stations that receive the signal from the 25 overflying satellites and transfer these to the local telephone networks.
The smaller size of the Globalstar network means that there is not as much coverage provided compared to Iridium.
Services And Products
Globalstar services include the following:
- Voice Telephony
- SMS text messaging
- Direct Dial-Up Internet
- Internet Broadband
- Short-burst messages that are mobile originated.
- A geolocation function accurate to within 30 km.
This is only available in areas where Globalstar provides Network coverage. North America is the primary market in which this service is offered.
Iridium Overview
The following provides an overview of the Iridium network.
Satellite Network
The Iridium satellite network comprises 66 satellites in low earth orbit (LEO).
These lower orbiting satellites (485 miles high) are close to the Earth and, in theory, should provide a superior signal compared to the other systems.
The LEO satellites rotate relative to the Earth in a north/south direction.
Because they move in a direction relative to the Earth’s rotation, they are called non-geostationary orbits.
A unique feature of the Iridium network is that coverage includes the North and South Poles. The Iridium satellite network has the most extensive coverage of the two systems.
At all times, four Iridium satellites are “cross-linked,” providing backup in case of failure.
The downside of LEO constellations is that the signals are subject to ionospheric interference at low latitudes.
Iridium uses L-Band frequencies more resilient to weather events than other systems.
