Somebody may have mentioned this but is the cruise control connected only to the right side coil? If so the wire connected to the coil could be shorting out somewhere. Possibly you could disconnect both ends of the wire between the CC and the coil and check for short to ground. Or use a megger if you can get your hands on one. The short may only occur when the wiring is flexing during riding etc. You may have to flex the CC wire harness to find it. This is where a megger can help.
I would think that if the CC wiring is causing it you would have a CC problem during the time when the engine is having problems.
Phil
Phil
