Low to Mid-Speed Wobble with Hands off of Handlebars
Ohio
1991 ST1100
Hey Guys,
I picked up an 91 ST a few months ago and have been loving it. Super fun bike to run, and I've enjoyed working on it. Since I've gotten it, I've done the standard maintenance (tires, fluids, filters, valves, etc) for it.
Something I've noticed that I can't quite identify is that when I removed my hands from the handlebars at lower speeds the handlebars begin to wobble. At first, slowly and then more aggressively, and it would probably throw me off the bike at some point.
The second I put my hands back on the handlebars, even a finger, it dampens the wobble enough for it to go away. When I was talking to the shop that did my tires, the guy working told me to just not worry about it- it's a 35 year old bike, and the owners manual even says not to take your hands off the handlebars. But I feel like this behavior is really strange, and I don't get the impression that if properly set up the bike will do this.
  • The wobble happens a low to medium speeds (15~55 mph) and goes away entirely at highway speeds. Wobble only happens when my hands are entirely off of the handlebars.
  • Using the throttle lock to maintain speed does not stop it, only putting my hands back on the handlebars.
  • Forks seem fine- no signs of leaking fluid and I don't think the suspension travel or stiffness feels alarming (I can't easily bottom it out)
  • Tires are inflated properly
    • This was happening before I had both tires replaced and balanced, and continued afterwards
  • I don't notice any play in the steering or "loose" feeling.
  • I put the bike on the center stand and pushed it back so the front wheel was in the air. Turning the handlebars through their range of motion I noticed that there feels like there is a "detent" in the center, that is that it takes a slightly larger amount of force to push it right or left when the steering is forward. When returning to the center position, it seems to want to "click in".
    • This is fairly gentle feeling and only something I noticed after paying close attention
    • I'm not sure if this is the intended function, or if this indicates some kind or wear or improper setup
    • Other than that, motion feels smooth and continuous.
I'm not entirely sure what could be causing this. I saw another thread where someone made an comment that over-tightening tapered bearings may lead to a "low speed wallow", so perhaps that is related.
Any thoughts or advice would be appreciated!
Edit: It's worth mentioning that I had to fix a clutch hose leak that I believe had been going on before me and with the previous owner. The frame seems to clean up "good enough" and I didn't see any serious corrosion, but it's worth mentioning.
Many here have had this experience. A search will show many possible reasons and remedies.
For me, ditching the Avon Storms cured it.
That detent is a sign of needing new steering head bearings.
this is an age old thing here. Its possible that it could be the tire, but if that doesn't fix it then steering stem bearings are the next step. It may be as simple as giving them a little extra turn to tighten them down, or you could go all out and replace them.
It seems like a lot of the posts that show up on google are just showing up as missing on the website, seems like half my issue is in my ability to find the posts
I just put new tires on, I think it was the Roadsmart 3's but I could be wrong, so I'll try checking the torque on the bearing as I don't want to spend any more money on tires.
For a little background, about 30 years ago the common wisdom around here was to replace the stock ball bearings with tapered roller bearings. Many of us did that with good success. However, it was also suggested that simply tightening the stock ball bearings may be all that was really needed. Its been so many years since I did it, I may have tried that initially and it didn't fix the problem, but I can't recall for sure because we were so focused on the tapered roller bearings that I may have never considered that option.
It doesn't take much time at all to try it, so you have nothing to lose. You can adjust it by feel, its obvious if it gets too tight, then back it off gradually from there.
Also, over the last 30 years one of the main suppliers of the tapered bearings has gone out of business, but I think All Balls still has them available.
If you feel what seems like a detent with the wheel pointed straight ahead there is a wear spot in the bearing race, which means the bearing is worn. The steering stem bearing needs to be replaced regardless of whether it is the cause of the issue or not. As a worn bearing can cause this there isn't much point in attempting any other fixes until this is eliminated as a possibility.
Some one else just posted the same problem, my St had the same problem, this spring I replaced the Roadsmart 3 's with a set of Bridgestone's T 32' s and readjusted the steering head bearings ( have tapered bearings from Allballs ), wobble is cured. Got 4000 miles on the T 32's , still behaving like new.
And yes your steering head bearings are worn out as others have said.
Tires and/or steering stem bearing replace/adjustment seem to cure it.
Indeed...
After mounting new Exedras on my '00, I could let it coast without a paw on the bar till it tips over...
3~4000 hard ridden kilometers later... ah, here it comes...
Once the tires have worn down to pretty much the end of their lifetime, cupping, howling while leaned, etc... the dec wobble gets really noticeable...
New tires: gone...
However, my personal experience and does not exclude any other of culprits mentioned above...
Front forks are not solid, each one moves independently.
That, in my opinion, is why tires cup, NOT due to the crown of the road but that's another debate.
When a tire starts to cup, even if it's very light, it will affect the action of those independent fork legs... even though the triple clamp is solid and the front axle and bolts to the fork legs are in spec. There's still some play there, not something you can move yourself but put a couple hundred lbs of tension on the front then add all the torque needed to keep the bike straight on a windy day or just making normal turns and navigational movements.... and those forks move up, down, forward, backwards...
One reason why many put new tires on and everything seems fine, for a while.
Obviously, all the above if your bike is in perfect condition... bearings and other suspension related items as well as speed, slow or fast, and the environment can add to the issues.
If everything looks good, just ride the thing and have a great time.
Or, just don't take your hands off the handlebars ... ;)
As was said, common problem, been around for 34 years or so.
The most permanent solution is usually a temporary one...
I'll read up on the manual and online about inspecting and replacing the steering head bearings, it's likely time. $50 from all balls isn't too bad
