Old fashioned incandescent bulbs only have the internal impedance of the metal that gives off light as current passes through it and heats up the metal and boils off photons.
Modern LED modules (not standalone LEDS) usually have an internal current and voltage (ie power) limiter circuit. I would not expect them to vary their brightness significantly with power fluctuations. LEDs by nature, are semiconductor junctions which have a threshold voltage for turn on (typically around 0.6vdc). After which, they are pretty linear in I-V characteristics up until their power dissipation limit is reached (which is a function of junction size and cooling). Then they just fail. The high end LED modules have power limiting and pulse duration circuitry to make them behave per the application required. Take a video of your LED lamps or modules and you may see them flickering where the eye alone does not detect this due to ocular persistence
