If you want something that puts light down the road then you must consider two things - power and beam angle.
most spots range from 30 to 10 degrees. (Floods are 30 to 60 degrees.) Many small lights are 10 to 30 watts.
The narrower the better for down the road, so look for 8 degrees......
The best place is to mount them off mirror mounts not down on the forks.
They should be wired from your high beam circuit.
Now the first thing is to upgrade your headlights to a set of F2 leds, as many will tell you here they are a big improvement over stock.
I ride a lot a night and I have a bunch of Aux lights on my bike that I do not use much since the F2 works so well....
But you want something better, that will compliment the F2s The F2s are 36 watts each so 10 or 20 watts spots lights do not add much.
So here are some "low" cost big guns, more than 30 watts each, that are 8 to 10 degrees. I have no affiliation with these products.
again these are too bright and should not be used in traffic at night.
With these you might want to mix a spot with a driving beam. Putting the light in the right place makes all the difference.......
The first listing has four choices........
https://www.amazon.com/Lightronic-L...coding=UTF8&psc=1&refRID=VZPW7VCXMM1X0NE44TKB
https://www.amazon.com/lightronic-Auxiliary-Driving-Offroad-Motorcycle/dp/B07CGNTJPH/ref=sr_1_892?crid=2OUDL83HQB60O&dchild=1&keywords=led+driving+spot+lights&qid=1584589887&s=automotive&sprefix=led+light+spot+driving,automotive,211&sr=1-892&th=1
https://www.amazon.com/Lightronic-5inch-Round-Lights-HeadLight/dp/B01LXOFZ5Y/ref=sr_1_1275?crid=2OUDL83HQB60O&dchild=1&keywords=led+driving+spot+lights&qid=1584590332&s=automotive&sprefix=led+light+spot+driving,automotive,211&sr=1-1275
https://www.amazon.com/Nilight-14035F-B-Pieces-Driving-Light/dp/B071WF61Z3/ref=sr_1_1175?crid=2OUDL83HQB60O&dchild=1&keywords=led+driving+spot+lights&qid=1584590199&s=automotive&sprefix=led+light+spot+driving,automotive,211&sr=1-1175
https://www.amazon.com/Lightronic-2pcs-Inches-Auxiliary-Lights/dp/B01C86H81C/ref=sr_1_980?crid=2OUDL83HQB60O&dchild=1&keywords=led+driving+spot+lights&qid=1584590036&s=automotive&sprefix=led+light+spot+driving,automotive,211&sr=1-980&th=1
https://www.amazon.com/RUN-D-Cube-Driving-Lights-Degrees/dp/B00T9GNAYE/ref=sr_1_29?crid=2OUDL83HQB60O&dchild=1&keywords=led+driving+spot+lights&qid=1584587499&s=automotive&sprefix=led+light+spot+driving,automotive,211&sr=1-29
Now you got more choices.......... and there is more, but you get the idea....
I have the 35 watt RUN-D 10 degree lights on my bike, but will swap them out with the 40 watt 8 degree lights in the first link soon.....
