Yes they did.
Ring and pinion would give you plenty of warning unless you popped the clutch to do a standing burnout and snapped something . plus 1 drive splines
ReSTored, I think you hit the nail on the head. I think I'll remove the rim for my next tire change and just bring that in. I'll still pass on changing the actual tire!
My 1100 has about 90,000km and the splines still look new. I use Honda Moly and I change the 3 O-rings every rear tire change.
In calling around when I first got the bike in 2003 none of the shops had Moly on hand (or even knew what it was) and all insisted regular grease was fine. None had or planned to order the O-rings saying this was not necessary. They all used the expression "We've never had a problem with this...."
With Moly Paste, the problem is that it can't be just any Moly grease. It has to be Moly 60 paste. (or at least, the manual says Molybdenum Disulphide paste containing more than 40% Molybdenum Disulphide.
In the symbols section before chapter 1 of the Honda manual, they make a clear distinction between Moly Paste and Moly grease - the latter being quoted as having 3% molybdenum disulphide.
That's a big difference and it makes you wonder if when asking the question, the service people hear precisely what you are asking, and are not just applying moly grease and think that that is Ok.
Honda no longer carries M60...seems the supplier had few users and dropped the high moly products. When dealer supplies are depleted, it's all gone. Honda has substituted M-77 paste. LOTS of low moly (3-4%) pastes and assembly greases on the market. I have spent some time searching the web for alternate sources for M-60 pastes and have come up...well...dry so far. Anyone find a source other than Honda?
There's Locktite Moly 65 and a few others.
