Need help with numbers for rear turn signal bulbs and brake light bulbs
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
I am at work and don't have the manual with me and need to order LED bulbs to replace rear turn signals and brake/running lights. What are they I seem to remember the brake/running light is a 7443 but don't know the turn signal #. I would like to try the amber red switchbacks for the turn signals. Any help would be appreciated I need to order some ASAP.
Thanks
T_C
St. Louis, MO
2005 St1300
8568
Re: Need help with numbres for rear turn signal bulbs and brake light bulbs
Correct, they are all 7443
SteveST1300
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
Thanks for the responses guys I finally found a post with the bulb numbers 7443 it is.
Kenly NC
07 ST1300A(P)
7649
Don't forget, you will need to upgrade to an electronic flasher relay, or be prepared to to wire in resistors. I went with the relay, it was 12 bucks, and I like plug and play.
(Yeah, that's what "SHE" said) Badum,tisss......
SteveST1300
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
Yes I already have a relay I changed the front turn signals to the switchback leds
STraymond
Cincinnati Area
'01 ST1100
8700
Well, Steve, maybe you should switch-back......
SteveST1300
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
I have Ray I switched the back turn signals to switchbacks as well red/amber
STraymond
Cincinnati Area
'01 ST1100
8700
This is getting too deep....I think that I'll just switchback to my non-internet life.
spiderman302 said:
Some of the fancier ones are too long and will not fit.
I assume there are no issues with the JDMs from amazon that you first mentioned.
Camarillo, Ca
2006 ST1300A
002552
the JDM's are too long for the turn signals but they work fine for the brake/tail lights. The shorter 60 led lights work for the turn signals.
