ST-Traveler
Hello all,
I have a 2007 ST1300 with 101,008 miles and went to replace my rear brake pads:
I just put on a set on new OEM pads on the rear, as I have done several times with out any trouble. But this time I put them on and noticed above average drag and the rear disc heating up (with out the brake applied) So I fiddled with it a lot, found out that the brake pads are fine until I apply final torque to the axle nut. Then the brakes grab/stick and heat up, and it is very difficult to move the rear wheel by hand. It is almost like the pads are too thick. But they are OEM so I don't know. I have not run into this before when I replaced the pads.
I put the bike on the center stand and put it in first gear and the rear tire rotates but there is noticeable drag.
I have put on the old pads and everything is back to normal.
Any idea's? I will need new pads eventually, so I need to get this figured out.
Thanks in advance.
Thanks in advance.
