The V65 is a fun bike to ride. Old school sit upright position with a zippy motor. I spent a lot of time trying to fix mine up to do long trips, but finally got too nervous about it with all the problems that kept popping up. The main problem was leaking valve seals, at one point causing some valves to crud up. The other problem was floats that would leak. When I changed the valve seals and carb floats I started making forward progress.
I tried the ST1100 and ST1300 and the 1300 was too much forward lean for me. The 1100 felt much better and doable.
I know the sound of wisdom when I hear it......I will do KNOWN working mods for performance. I had two things working against me.....first, I didn't know I had a California bike (I might have passed on it if I knew), the second is I don't think it has run on all cylinders at idle since I got it. Hard to evaluate a bike for power when it isn't running quite right. Ran pretty good on the freeway, though.
My jets come in on monday, so I will be going thru the carbs during the next week.
Thank you all for your help and insight.
