No Headlights??? Help
Shropshire
ST1300 Pan
On the way to work this morning and the headlights just cut out... rode back home and checked the following - no joy; any ideas?
2011 ST13 UK model
Symptoms
1. No Headlights on dipped or main beam (rocker switch in normal or pressed forward position)
2. Main beam comes on (both headlights) when pressing rocker switch and holding down the passing switch
3. Tail lights and brake light work normally
4. x2 little running lights (above headlights) work fine
5. Indicators work fine
Checked
Removed and checked both 10 Amp headlight fuses with multimeter for continuity - All okay
Unscrewed LH switch cluster and sprayed with electrical cleaner and operated all switches
Still no joy - any ideas?
Cheers
Do UK STs extinguish the headlights while starting the bike? If so the starter switch might need some attention. If not pretend I never said anything.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
:plus1: There is a little piece of bracket that holds together the headlight shutoff when starting switch. That broke off my sons 05 ST1300 and he had no headlights. He ripped into everything to no avail. I torn into the starter switch and found the problem right off.
Shropshire
ST1300 Pan
Thanks both, gave both switch housing a good spray with electrical cleaner - 15 mile test ride and all is now working fine :D
thanks again.
cheers
