non-ABS: BT 020, 023, T 30, T 31, T 32, T 33... ??
First of all:
zis is about ST1100 non-ABS (and maybe the ABS-I/TCS)... so to all those ST1300's out there: stay out of it... :wink:
110/80 ZR 18 M/C (58W) TL front
160/70 ZR 17 M/C (73W) TL rear
speed index: V
the trusty Exedra G547/548, gone, irreplaceable, vanished...
But what is actually a worthy successor? 🤔
From what I can gather will all those BT and T tires listed be shredded to pieces within ~6,500km/4,000miles on that bike...
Whereas the Exedra's easily gave 12,000km/7,500miles... sufficient to last through my 8~9,000km/5~5,600miles tours, and then some... 🤔
And I'm not really in the mood to organize a bivouac somewhere up in Norway or Sweden to replace my tires half way through the ride...
So what's the verdict?
Sticking with stock sizes, T32's were all I could find from US suppliers last month . My first time with these, so can't give any historical data. Hopefully the choices improve as we move into warmer weather.
Hopefully I can find what Uncle Phil recommended to me, Bridgestone Battlax BT-020M for the rear. My 300 Canadian dollar Dunlops roadsmart 3 have done reasonably well, have to check the odometer to see how many kilometers they have lasted.
Hi Martin, I’m no expert on tires here, just some info on what I’ve been running since 2000 on my non abs y model, specifically for my location in south east asia(high humidity with fairly high ambient temp and lots of sudden downpours/monsoon seasons and decent smooth asphalt roads)
Original excedras G547/548: very high mileage and long lasting, good for touring on highways but very slippery and rear losing grip/sliding during up/down city parking complexes ramps when new, factory set lasted me around 28000km if my memory is correct. Never went back this set again since then. They can still be ordered via Amazon locally from Japan, long wait time.
All BT series lasted me around 20000km+-, excluding punctures.
T30/31/32: 18000-22000km from my dated records past 8/9yrs.
My personal preferences is T32 as they perform exceptionally well in the wet, competent in dry and they last decent mileage, although from records they seem to wear faster than T30/31 slightly.
Charged another set 2weeks ago down to wear limit but due to limited sizes available, had to go with mix/match F/R T31/T32 with 110/80-18 and 170/60-17(no 160/70-17 avail). I’ve run this rear size before due to availability, bike rides fine except more effort needed to put on main stand, side stand clearance lower as well.
T33 is the latest but no feedback from any 11 owners yet, the costs is also much higher that T31/32, however it’s not available as option for me here.
St1100 tire sizes/brands are much harder to come by nowadays. BT series sizes not available in SE Asia anymore. Only T31/32, T33 sizes not available yet.
Finally someone opens up this barrel!
Thanks ST! 😁
1100 only??! Pffft am going to listen in and apply, period. When it comes to STs and tires I only find 2 levels of info.. 1- current best tires, but not associated with any specific bike models, style yes, ST specific, no. The other are the ST tire reviews, but those are mostly over 10 yrs old and/or old enuf that those recommendations are either discontinued or replaced. Add ride style, road condition, weather, weight and thottlethrist, well you know, tires are like toilet paper.
From a current spec perspective, I like the Michelin's, but either can’t find sz or don’t make. I think I don’t like what’s on currently.. go figure how I could say that, Avon Spirits, always been a proponent of Avons, had them on my 04 F6C.. not going to get tires now, need next shakedown cruise to tell me that, but I will be and I am listening… popcorn popping, ya’ll are welcome to dig in!! 👍🏼
Thanks in advance!!
As I have said before, BT020 bias for the rear (proper size and happens to be for the BMW K1200LT).
Since all of my ST1100s are ABSIIs, I use the BT03X flavor I can find in 120 width.
If they have a 110 width then it should be fine.
If you have vehicle inspections, then I suppose you can't run a 120 in place of 110 though it works fine on the 110 rim. ;)
Odd, cause after a 300km "break in" those Exedra never let me down, despite of weather conditions...
I like the direct/precise steering the bias/ply provided (whereas radials always have that diffuse, mushy front end, bike drifting left<>right in the lane...), as well as the wide safety margin; when pushing the envelope they always reported a "gentle warning", by front and rear "drifting" equally (one could actually play around there with the throttle in long fast corners...)
So I never had a sudden wipe out with the Exedra, whilst any radials I'd ever tested showed exactly what you wrote: a sudden loss of traction on the rear, with NO warning whatsoever... 😒
Comfort is also a topic...
The bias/ply construct features a "softer" thread surface with rather stiff sidewalls, so absorbs like cobblestone roads nicely, while giving a precise track...
A radial construct has a stiff thread surface with more thin/softer sidewalls, thus harsh vibrations and bouncing on bad roads, while giving that mushy tracking/feedback due the sides flexing...
2 years ago the Exedras were double in price than the last time I bought them, I loved those tires too and long mileage as well.
I went with the Dunlop Roadsmart 3 and they have been great so far. Radials you have to keep inflated properly (otherwise they steer oddly), not forgiving like bias tires. I am running the fronts at 40 psi and rear at 42 psi and find the Dunlops good in the rain and dry roads, they will howl in the corners unlike the civilized Exedras.
I've also tried Michelins in the front and Metzlers in the rear and they worked well too with very long mileage. I always use the proper sizes.
Well, many simply overlook that there 5 different ST base models:
ST1100 non ABS
ST1100 ABS-I/TCS
ST1100 ABS-II/CBS
ST1300 non ABS
ST1300 ABS/CBS
and then add various national configurations to that...
Yes, not to mention the wildly accepted best ST..
CTX1300!! sorry, had too.. 🤣
That would be RoadSmart IV now... and their prices are +30% over Bridgestone... worth it? 🤔
(and I'm biased... I had two(!) low-speed low-siders, both while gently coming out a tight back-sweep since '92... and both with Dunflops (103 & 205)... pfffff... :rolleyes:)
BT02*'s are out... no front tire avail... (and in BT46 no rear...) 😒
Leaves one of the T3*'s...
Not a chance... 😑
They're getting increasingly tedious every year... and then you show up with a 25 year old MC... :rolleyes:
Running lights? Horns more audible then the OEM meeb-meeb? You'll never hear the end of it... and fail of course...
(but I always ROFL when the ST catapults out the brake test stand... with the 'inspector' dearly holding on... yep, those well maintained stoppers are biting... 🤣)
I was hesitant at first due to those Dunflop events I saw on here, but thought I would give them a try. They were also cheaper than the T32 or Exedras by a long shot.
Too bad you can’t get the RoadSmart 3.
You actually have a lot more choices compared to me, and the prices are actually very reasonable(cheap for older T31/32) even for Bridgestone comparing to the other brands.
https://eu.mynetmoto.com/shop.cfm/tyre/110/80/18/all/all/motorcycle-tires.html
I was very envious when searching for st11 tires few mths back, at least you have the correct sizes and don’t need to call shops and distributors to ask for quotes and availability.
I am currently running a Shinko SR999 on my 2006 Wing and I am seeing some good results. I noticed this tire is also available in 160/70-17 as well for around 209 bucks in the States. Just my 02 cents. Hope everyone has a great day!! Ken
Not a chance... 😑
Love the feedback! As I take this in it’s a reminder of how lucky I am. You may hear that alot from me but if it weren’t for God, the grace of his son, who I couldn’t imagine to begin to accept such pain and suffering to be inflicted on my son, my seed, my future. Yeah, it’s a slippery slope.. sorry, it’s not even Sunday.
Anyways..I haven’t had my coffee yet.
Back to the point.. here in Florida not only there are No gov vehicle inspections of any sort, 2, 4, even 6 wheels, no mot or whatever it is in the UK.
We used to, in different decades, different times,.
omg my car isn’t going to pass..!! yeah don’t miss that at all…and further for 2 wheels; 18+ no insurance required, no helmet needed, basically their saying.. “it’s your life, do it how you want, but we say 4+ wheels will always win against 2, good luck out there, be safe lol and list me as a beneficiary!”
I need to stop here, go get some caffeine! 😜
Wouldn't find motorcycle w/shops who stock them either...
have to search online and they come from anywhere across continental Europe...
Changing tire dimensions for newer bikes plus making previous ones sparse is a sales pitch...
by this they just intend to 'nudge' people to buy new vehicles...
(same with car tires; the 185/65R14 for my trusty '96 Carina/Caldina are completely 'exotic' dimensions today and hard to find...)
Further considerations:
the roads here are topped with winter-asphalt for grip in wet, cold and winter conditions, hence quite abrasive...
there also rumors that tires designated for regions with colder climate, are made with softer compound...
both contributing factors to a quicker wear...
My Dunlop Road Smart 3 have 13,212 kilometers. Since October 15 2023, till February 27, 2026 . Missed 14 months of riding due to Going through Chemo for Myeloma Cancer. So here's what they look like now IMG_7769.jpegIMG_7770.jpeg
The front shows some 'wallowing' (heavy on the brakes? :unsure: ) and likely cursed by 'Shamane Headshakin', the rear seems pretty smooth though...
BTW who wears the Comstars in the background? 😋
That would be "Babe" she is a 83 CX650E , and yes the front tire is wallowing on the ST. The St has had the headshake at 60 to 80 km if I let go of the handle bar with the throttle lock on. Will be checking my steering head bearing tightness when I have the front wheel off. Was happy with the performance of the Dunlops for what I paid for them, I think I got my moneys worth at 300 Canadian. G
