- Joined
- Sep 25, 2009
- Messages
- 3,074
- Age
- 69
- Location
- West Des Moines, IA
- Bike
- 2022 Kymco AK 550
- 2024 Miles
- 003621
- STOC #
- 8058
Just sitting at my kitchen counter today and decided to do a little work on the trailer harness cable. Added the coil cover over most of it, especially the part that will be exposed to whatever is kicked up from the road. I just happened to have that coil cable cover that fits this sized cable. I also added large heat shrink tubing to both ends of the coil cover to tie those ends off.
While I was at it I added the spade connectors to the 2 wires that will need them. The right turn wire (green) and the left turn wire (yellow) will need those to plug into the relays that I am waiting to arrive later this week... hopefully. The wires for ground (white) and tail (brown) and brake (blue) will simply need to have the insulation stripped and the bare wire ends will fit into Posi-Tap connectors on existing wires on the bike. BTW- existing wires means the relay wires I already installed for the LED light bar I installed and NOT the factory wires. I never take power for any farkles from any factory wire unless it is designed specifically for something.
Many years ago I used to solder all my connections but then was reminded why automotive wires connections, as well as many aircraft wire connections, are crimped instead of soldered. Crimp connections are more reliable in environments where there is a lot of vibration. Soldered connections have a tendency to crack and fail due to the vibration.
And for those who might not be able to see the attached photo here is the link to the photo that will show in a separate window.
New item by Robert Shwery
