Hi. I've done some scouring of the forums before posting. Please be gentle.
Here's where I'm at:
ST1100, 1992, with the 40 amp upgrade done about a year ago. 70k+. I've had the bike for just under a year and about 5k. PO did the alternator job. She's been reliable as can be - until about 2 weeks ago or so. Battery is AGM and manufactured 12/21. Never had dead battery issues with it before a few weeks ago.
What's not bone stock, at least that I'm aware of?
Thanks in advance!
So here's the longer story with appropriate drama for those interested in such things:
I recently added an old trickle charger pigtail to the battery to help keep things topped off, as we had a recurring bout of the bad weather in Maine, and it's a pain to pull plastic just to trickle charge. I ride year round - as long as the roads aren't snow/ice covered. But I hadn't hooked up the charger. (dumb.) Soon, I found a dead battery. Easy: cold, under my CycleShell, no ridie, no startie. I charged her up and rode her. All seemed normal.
Storm happens. Two days later, I go out to start her for the morning commute. I'm down to 6.5 volts. Damn. Off come the plastics, on goes the jumper. Start, warm up, ride to work and back.
My onboard led voltmeter usually reports about 13/13.5 volts while running - though yesterday it was down in the 12s, odd. A second voltmeter with USB ports running directly from the battery is always a bit higher.
Dead again after a couple days. I pulled the trickle pigtail, as it was the "new thing" on the bike. (Maybe there was some funky thing in there?). I recharged and rode.
Two days later, after not riding, dead again. So I pulled the fuse from my second voltmeter thinking perhaps I'm getting parasitic draw from those USB ports - even though it's turned off at the voltmeter/usb switch. The bike was apparently still drawing power while off. (and probably not just that lcd clock)
I removed the leads running from the voltmeter to the battery to really eliminate that possibility.
What wires are there on the battery, you ask? Negative lead; Positive lead; and a red wire coming from a Fuse block to the positive lead. (I think that wire runs from the alternator over to charge the battery, as removing it gave me 0 volts on my onboard voltmeter. Hooking it up gave me 13.5.) That fuse block sits just to the left of the battery (when facing it), and it's not the one that sits to the right of the battery and a little above it.
This is about my 9th bike, but there's a bit more to this baby than what I'm accustomed to. My newest ride before the '92 ST was an '84. Mostly, I wrench and ride late '70s and early '80s Hondas.
- 40 amp alternator upgrade
- LED headlight kit
- On board voltmeter (switched power)
- Bypassed thermostat fan switch for manual control at bars, mainly because fan switch failed and I have yet to swap in a new one.
- Considered maybe ignition switch has something going on, as I read some threads suggesting this issue the other day. Disconnected battery, doused internals with electronic parts cleaner, worked key back and forth 40 times, etc. Hooked battery up. I have yet to unplug ignition and clean contacts. Maybe there's something to ignition drain while off?
- Tested for power at fan switch just because. Nothing with the bike off and battery connected.
- Pulled all wires associated with aftermarket usb/voltmeter running directly to battery - even though it has an off switch.
- Load test the battery. This seems like a reasonable move, as they can go bad. I've not done that yet, probably the easiest thing to try.
- Test for the parasitic drain with the following method: "Once you get your battery sorted use a DMM set to measure current (Amps) in a low range and connect it in series with a battery lead." I'm not sure what a DMM set is, probably because I have too many other acronyms floating in my head. I've got a multimeter with probes and a digital readout - is that the DMM?
- Alternator diode may have failed. (I hope not!) Is that internal to the alternator, which would mean I'd need to clear shop space and move my project bike for a major operation? Or is the diode hanging off the side of the bike somewhere under some plastic? Also, I do get charging while running - 2 voltmeters show it, one switched and one directly on the battery, and my multimeter confirms it all. Would diode failure mean parasitic drain while off but charging while on?
Thanks in advance!
