John,By a number of reports over the years, this is supposed to be a better fit than the K&L version. FWIW
Bush,Rebuilt mine with a K & L kit this summer and it failed again within 300 miles. Forget K & L, or forget the rebuild entirely and remove it. I know it is a safety feature, should the bike go down and fuel keeps pumping without it, but if my '96 burned up in a blaze after a crash, it wouldn't make much difference to the insurance payout on such an old bike anyway.
You simply connect the fuel filter directly to the hose going to the carbs - the one leading out of the fuel cut off valve to the carbs.John,
I came to this
Bush,
The fuel cock on my ST1100 is leaking and I was researching for a repair kit and noticed your post about removing it entirely.
Did you just join the 2 pipes together?
If so, how did you join them?
Regards,
Graham Watson
Bush,You simply connect the fuel filter directly to the hose going to the carbs - the one leading out of the fuel cut off valve to the carbs.
You will also need to securely plug the vacuum hose going to the valve.
Uncle Phil,Been running all 4 of my ST1100s (3 of them for over 100,000 miles) without one. I figure if one of them gets turned upside down, I've got bigger issues to be concerned about … IIRC, one of the screws that comes off the mounting bracket is just about a perfect fit for plugging the vacuum line.
While you're thinking about it, pull the #3 spark plug and see if its fouled. Depending on how your valve failed you may have had raw fuel going into the #3 cylinder through the vacuum line attached to the valve, which eventually fouls the plug, and may also explain your increase in fuel consumption.This p.m. after starting the bike for the 1st time after the water pump rebuild, I could see the leak.
That was probably the reason why fuel consumption had increased by about 10%!
they can fail without actually leaking fuel externally. The diaphragm gets a tear and fuel leaks through the diaphragm and into the vacuum line that normally activates the diaphragm (when its not torn and can hold a vacuum). The symptom is a strong gas smell, but usually when the bike is parked after shutting it off. Particularly noticeable if parked in a garage.For quite some time there was a smell of gas which I didn’t investigate too closely and other people commented about it.
This leak is not consistent, as after a few seconds it stopped but I now know the petcock needs replacing
Dwalby,they can fail without actually leaking fuel externally. The diaphragm gets a tear and fuel leaks through the diaphragm and into the vacuum line that normally activates the diaphragm (when its not torn and can hold a vacuum). The symptom is a strong gas smell, but usually when the bike is parked after shutting it off. Particularly noticeable if parked in a garage.
when you saw fuel dripping from the petcock I assume you mean from the split in the two halves of the petcock, not from the fuel line connections, right??
FWIW, as others have said before, a good percentage of the ST1100s still on the road have that valve bypassed, so you'll likely be part of the majority, not the minority.So, if you hear of a rider who was burned to death in a fiery wreck, it could be me!
Add some yellow (gas line)Teflon tape to the screw.Been running all 4 of my ST1100s (3 of them for over 100,000 miles) without one. I figure if one of them gets turned upside down, I've got bigger issues to be concerned about … IIRC, one of the screws that comes off the mounting bracket is just about a perfect fit for plugging the vacuum line.
