Just installed a new Progressive 465 on my 02 1100 ABS. Once I got it into my head that it has to be installed upside down (relative to the stock shock), it went easy as pie. Except that the shock design (using a spherical bearing in the eyes) allows the shock to rotate about 3/8". There is no play up and down, and none side to side. But I have never installed a shock that seemed so odd. is ... Look at the following pics of the swingarm mount. The 1st pic is with the shock rotated to the left. The 2nd pic is with it rotated to the right.
The camera location, angle, and zoom was not altered in between the shots.
I'm going to call Progressive tomorrow am, but I need to leave on a trip at about 0900 at the latest so I will not have time to change anything. It seems ok bouncing up and down in the garage, and I do not see any means by which the slight free rotation could cause a handling problem. Has anybody with a 465 seen the same thing?
I actually spent a bit of time playing with this, even going so far as to try and insert another slim washer in the shock housing. But the housing is tight to the shock body washers on both sides (a steel shoulder washer with an o-ring). The rotation is a function of the spherical bearing doing what it's supposed to. But it sure seems odd... The top mount is exactly the same (albeit with a smaller diameter bolt and shouldered washers), but with the shockeye recessed into the frame mount it is pretty much invisible.
