**Quantum fuel pump replacement owners BEWARE, and make the necessary correction immediately**
In late October of 2020 I ordered and replaced the fuel pump on my 2006 ST1300 @49,300 miles. Today while riding with my buddy over 100 miles from home while anticipating a great ride through Mt Lemon in Tucson, AZ, as I entered the first turn on the Catalina highway I downshifted from 2nd to 1st and lost power and the bike stalled to where it was a dangerous situation since beautiful days like today bring everyone out. Luckily my buddy noticed that I was having trouble, we quickly discussed it through our intercoms and my bike just died. The bike would crank, but would not start. Of course this happened within minutes of fueling up. Luckily I was able to turn the bike around, now facing down hill and coasted almost a mile to a fairly safe spot on the side of the road.
A few months back Igofar helped me with my lower tank since the lip had bent when I caught a wire between the tank and lid when replacing the lid and gasket after replacing the fuel pump. At that time Larry mentioned that I should replace the hoses that attach to the fuel pump since they did not specify that they are rated for submersible fuel. Recently I noticed fuel fumes coming through the housing and contacted Larry. He reminded me that I should not only replace the gasket, but also the two submersible fuel hoses and crush washers. Since AZ is getting to where it becomes too hot to ride, I ordered the parts and decided to install them once it became too hot to ride. I also put silicone around the lower tank housing as a temporary fix because I only noticed fumes and not gas was leaking.
Back to the story, so now I am at the side of the road with my buddy, I have some tools but I am missing some depending upon what needs to be done to resolve the issue. My buddy has a friend that he grew up with in Kentucky that lives a few miles from where we stopped so he called him, within 20 minutes he came by with some tools and a 3 gallon gas can.
I heard the fuel pump pressurize when I turned the key on, so I figured the pump was good, however I remembered what Larry told me, and I have read a few of his posts warning everyone to order and replace the Quantum hoses with the Honda fuel submersible ones. Well I captured some gas, but lost some too. After removing the silicone, cleaning it to prevent any from falling into the lower tank, and removing all other parts and then the nuts on the lower tank I was somewhat glad to see one of the submersible hoses was bloated, and the other bloated and split in the center section.
Luckily I sent my buddy to the auto parts store and he purchased a manual pump siphon, gas can and a few pieces of 1/4” (I believe) gas hoses. It took some time, but after replacing the wrong hoses with newer wrong hoses I was back on the road.
The moral of my story, if you think that this is not going to happen to you, you are mistaken, I only had 4400 miles on these hoses when they not only failed, but placed me in a dangerous life threatening situation. I plan to contact Quantum tomorrow, but if you replaced your fuel pump and did not order the specific Honda part which is designated for submersible fuel, or if your replacement hose did not specify that the hose is submersible fuel hoses, then IMMEDIATELY REPLACE IT WITH THE CORRECT FUEL HOSE.
This is extremely serious and extremely dangerous and shame on Quantum or any other manufacturer that provides the wrong type of fuel hose since your life could depend upon it being what is specified for by the manufacturer.
Your mileage may vary, but I wouldn’t gamble with if this is going to happen, but when.
Please replace your submersible fuel hoses ASAP. These are the part numbers for my 2006 ST1300;
HOSE A, PUMP 16711-MCS-G00 $2.99 @partzilla
HOSE B, PUMP 16712-MAT-D01 $3.334 @partzilla
Well I am joining the Quantum fuel pump club. With 218k km's on the clock,,, no point waiting for a roadside repair. For the last 85k kms,,, I have used a fuel lubricant,,, and will continue to do so. Hopefully,,, the original Hose A and B will still be in good shape. I have ordered the base gasket from Honda Canada,,, for about $18.cdn (compared to about $9.us from US sources). Should arrive mid next week,, but not sure when it will be changed out,,,,, that can wait for a rainy day. cheers,,, CAt'
Any fuel related symptoms at all, or just preventative maintenance? What type of fuel lubricant? Marvel mystery oil?
Mostly,, it is just the mileage,, Kevcules. But there is also an aspect pertaining to my Bazzaz project, that I will elaborate a bit on in that thread. For the first 40k km's of my ownership,,, I used MMO. Then I switched over to the Lucas product,, and am still using that. Either will do the job. Actually,,, I have the Lucas product poured into an old MMO bottle,,, just because the pretty red bottle is a lot handier than the bigger awkward Lucas 1-litre jug. So I am getting the best of both products,,, yes,, no,,, CAt'
I've got several thousand miles on the ST1100 that I installed the Quantum and cheap EBay fuel regulator.
I did use submersible Gates hose in the tank and I have been extremely happy with the results.
It could be my imagination, but I seem to be getting better fuel mileage now based on my butt dynamo. :biggrin:
I am going to throw this up here,,, just for the consideration of those who know more about fuel pump function than I do. It may not be a relevant concern to our installation. But for those using the quantum replacement (like me, soon),,, it's worth a read. Also,,, I noted on the Quantum website,,, that they market the 8mm black gas line,,, as "submersible". Cheers,, CAt'
ps: I just noticed that the thread listed below is from 2014
