I was actually pretty far off in my earlier description of how much roll off is needed to cancel CC. I’m out riding today and found it takes very little pressure to disengage it but it’s still smoother for me to brush the brake pedal while maintaining speed with steady throttle.I think in 2010 the switch gear changed for the turn signals so maybe the cruise did as well. On my bike there was a recall on the cruise control switch and it was replaced by an updated unit.
Whoa... slow down there whippersnapper... you still gotta read the owners manual and take the owners test to get your complimentary jar of grey poupon..All this talk of cruise control means I’m actually going to have to try it.
Mine tooGS mirrors came standard with mine.
To go with my jardonnae?Whoa... slow down there whippersnapper... you still gotta read the owners manual and take the owners test to get your complimentary jar of grey poupon..
I thought it was Chardonnay ...?To go with my jardonnae?
Not sure why no one has cleared up this misconception but Honda’s flat 6 engine is not a Boxer. A flat (horizontal 180 degree V) engine uses one crankpin per two horizontally opposed cylinders, the two opposing cylinders reach TDC 180 degrees out from each other (never appearing to be boxing). The boxer mill is a special case of flat engine that employs one crankpin per cylinder, the two cylinders opposing each other reach TDC at the same time (boxing).Boxer engines are great. Not only a claim to fame in the BMW world, Goldwing engines are also boxers!
I think the early ones were mounted in line with the frame ...or industrial and marine and not used in vehicles. Maytag even used its Model 72 3/4 HP flat-twin engines to power washing machines.A non-boxer flat twin would have one helluva side-to-side wiggle.
BMW boxer twins have always had a rocking torque couple because the crankpins are not in the same vertical plane. As the pistons accelerate and decelerate in time to crankshaft rotation the amount of crankpin offset creates the couple. This torque couple yaws the engine back and forth around the vertical axis. When the engines were 600cc or less and pretty much every other manufacturer was building singles and parallel twins with natural imbalances of greater magnitude, the boxer twin was considered very smooth however when the displacement grew over 750cc and Japanese inline fours became commonplace BMW boxers were no longer the smoothest engines in the market. By the time the displacement grew to 1200cc in the 2004 R1200GS (actually 1170) BMW added a counter balance shaft to reduce the torque couple.A non-boxer flat twin would have one helluva side-to-side wiggle.
I have a riser like this and my handle bar mirrors are factory (09) at Amazon 1in up 1/2 in backYeah they don’t.
Found these though.
Mirror Adapter, 6mm
Check out the deal on Mirror Adapter, 6mm at wunderlichamerica.comwww.wunderlichamerica.com
And they made a great go kart engine.I think the early ones were mounted in line with the frame ...or industrial and marine and not used in vehicles. Maytag even used its Model 72 3/4 HP flat-twin engines to power washing machines.
Tom
Maytag
