Came back to this post because this next time being into the forks (Jan 2024) after doing the above upgrade, the left fork's bottom socket bolt is just spinning in the piece it inserts into and I'm at a loss as to how to get that inside piece to not rotate so I can back the bolt out. The service manual says to temporarily reassemble everything but that didn't seem to make a difference yet in my case.
Any ideas? I haven't reached out to Race Tech yet to see if they have any suggestions, but will if I can't figure something out by the end of next weekend. On a timeline for getting everything back together!
Are there any instructions on the fork caps adjustment anywhere?
How many turns are they from full-in to full out on preload and compression and rebound damping?
How much sag did you set up the front to with the preload adjustment? How many "turns out" would that be?
And what would be a good "turns out" starting point for compression and rebound damping adjustments?
Thank you.
