schla
STOC #7008
$300 to do the rear brake pads? Holy markup, Batman! The pad set is $45 and they take about a half hour to install at a leisurely pace. Add 10 minutes if you stop to clean the pistons and disc.
The problem in your case is not a result of an engineering or manufacturing defect, which means it isn't covered by the warranty.
What you have there is a defective dealer service department which should be replaced immediately, if not sooner.
--Mark
I exxagerated the cost a bit. I think the pad replacement was actually about $140, I also had both tires replaced (read my previous post completely) which made it a total of $300. oil change as well and whatever else needed to be done at 25k miles.
as for the warranty issue, thats what I have been reading in this thread: it seems to be a bad design, thus the question if anyone actually discussed this with Honda, and why I felt it should be a warranty or recall issue. This bike was garaged it's entire life and hasn't even gotten dirty. the dealer excuse for the $200 rear caliper rebuild was dirt due to the recompression of the piston into the cylinder after the brake pad replacement. They said they try to clean it as best they can... I am more concerned about the fact it still is having a problem. What needs to be done? replace the darn caliper? :-(
shop is very good. any dealer is going to be pricey. I live iun the SF bay area and that also adds to the labor cost. no markup on the pads, they actually only charged me $37 or so for them. I wanted dealer work this time around as it was the first service since I bought it last year.
