Not sure. I believe it’s just the model number.Looking for a new rear absorber too... Does it mean that number "465" is a rigidity of a spring in lbs?
Wilbers is definitely the way to go! I just had my front suspension done and will install Wilbers Nivomat very soon. From both I made a video (rear will follow, and part 2 of the front will air Friday the 26th of November). If you watch the video I also mention that you will get a discount if you mention 'Chiefpep' in your inquiry. Just send the guys at HK an e-mail. They send all over the world! Perhaps that helps with making your choice?! Good luck!Looking for a new rear absorber too... Does it mean that number "465" is a rigidity of a spring in lbs?
My St1100Y with 38,000 miles on it, didn't handle particularly well in the Spanish Picos mountains. It was fully loaded for touring and I am no longer built like a racing snake. Back home and unloaded, I still seem to feel every bump, although it definitely isn't bottoming out, at either the front or back.
So, I took my stock rear showa shock to the local specialist, where it would be £50 to test it, but was told in their opinion it was probably not worth doing given it was 22 years old and had done 38K miles already.
They suggested avoiding a new stock showa ( £440 ish ), as they are an unserviceable shock , but suggested YSS or Hagon, in the region of £350. Or a Wilbers at around £550, although they were unsure if the improved ride was worth the extra £200.
Is it worth the extra?
I purchased the Hagon,and am very happy with it, it has improved my ride, much better than the progressive. I have heard good things about the Wilber and the YSS I can’t comment if the Wilber is better than the HagonMy St1100Y with 38,000 miles on it, didn't handle particularly well in the Spanish Picos mountains. It was fully loaded for touring and I am no longer built like a racing snake. Back home and unloaded, I still seem to feel every bump, although it definitely isn't bottoming out, at either the front or back.
Will this work for the ST1100 rear shocks?You could send it to Holland...Don't know the shipping costs. Revision is definitely worth it. € 250,- max. The service and details how it's done can be seen in the video.
I have heard of folks getting the ST1100 rear shock 'rebuilt' but the performance improvement of a Wilbers or Hagon is noticeably better.Will this work for the ST1100 rear shocks?
Good Evening. Is that the Type 640 you got? https://www.wilbers.de/shop/en/Motorcycle/Honda/ST-1100-Pan-European-SC26/?year=1999I have heard of folks getting the ST1100 rear shock 'rebuilt' but the performance improvement of a Wilbers or Hagon is noticeably better.
And the Wilbers (and IIRC) the Hagon are both designed to be rebuilt not like the stock ST1100 one.
I've got Wilbers (from Germany) on all four of my ST1100s and I am very happy with them.
Terry,,, not sure if you have mentioned before,,, but what spring rate did the yss come with,,, and did you preload it a bunch like it appears in the photo ?? thx, CAt'I recently put a YSS shock into my 1300 and have been super-happy with the result. I bought mine from Firefox Racing in the UK and they were good to deal with. I know they also make a shock for the 1100.
The spring is a 180N/mm I believe. It does not appear to be excessively preloaded and the adjuster turns reasonably easily; just because there is a lot of thread showing above the adjuster, that does not mean that the spring has been compressed that much. I haven't attempted disassembly but I expect that the preload ring can be unwound far enough that the spring can be removed without needing an external compressor.Terry,,, not sure if you have mentioned before,,, but what spring rate did the yss come with,,, and did you preload it a bunch like it appears in the photo ?? thx, CAt'
