Decided to start its own thread:
I haven't looked at my actual bike's innards yet, but I have scoured the wiring diagrams and photos, and want to do something kinda similar to lessen the ignition switch's load. I would appreciate the opinions of the wiring guys.
My intention is to re-feed the headlight fuse, which appears to have its own separate supply wire to the fuse block, directly from the battery via a new fusible link. The headlights use relays, so why switch the power? Now, doing this also means the wire feeding the headlight-interrupt contacts in the starter button will be hot.
However, I also intend to disconnect that and instead feed the headlight-interrupting contacts from the switched side of the engine-kill switch, so the headlight won't be on when sitting with the engine off, but I want power on. The running-, tail-, and gauge lights will still be on, but the battery drain will be much lower.
I'm also thinking of adding an ignition-coil supply and relay, so the bike's wiring only carries relay-coil current, possibly allowing for a hotter spark. The power wire could share the new fusible link and wire that I mentioned above, figuring that a 30a link and 10-gauge wire should be plenty heavy enough for everything.
The reason I'm looking at the headlight circuit first is that it's the only 20a fuse, and I haven't swapped them for LEDs yet. When I do, I could even lower the fuse rating, but figure the direct supply will still allow for a slightly greater voltage at the lights, same as the ignition relay idea. So, what do you guys think?
