I'm trying to remove the left-side Throttlemeister bar end, and when I turn the allen bolt, I can hear the entire mechanism turning inside the bar. The bike came with the Throttlemeister installed, and I'm guessing the PO used loctite on the bolt.
I was able to remove the right-side Throttlemeister bar end using brute force (pulling and twisting the bar end). So far, this method hasn't worked on the left side - I believe the left-side uses the stock internal weight assembly. I also have Honda heated grips, so I don't really want to cut the grip to get a better look at the bar.
Any ideas?
Thanks
Any ideas?
Thanks
