Replacement SAE connector for Battery Tender
Houston, Tx
2003 ST1300
5952
Where do you find crimp-on or solder-on replacement SAE connectors?
There is a broken wire by my original BT connector (needs jiggling for contact) and the connector needs to be replaced ( it doesn't look like the original connector is serviceable!).
Napanee Ontario Canada
2008 VStrom 650
Those two conductor connectors are common items... I found them at Canadian Tire Automotive up here and I am sure that Autozone type stores in the US would stock them as well. The ones I found had a short length of wire attached so that they could either be crimped or soldered on.
MidLife
Houston, Tx
2003 ST1300
5952
Thx. Will check my friendly neighborhood auto part stores.
