Ride-On Tire Balancer and Sealant
No worries about disagreeing with someone, it's natural as we all have our own opinions.
It's easy to dispute someones opinion, but that doesn't get us anywhere other than having a difference of opinion. I would suggest , and I have followed my own advice, researching the idea or opinion , and or TRY IT. I have tried the balancing beads , and they work.
I have personally witnessed a tire, which I had put Ride-On in, get a small puncture, in the middle of the tread and the tire went flat. This was on a friend's RT. We were able to plug the hole and continue on but the puncture was exactly where the Ride-On should have been distributed (ie. center of the tread) and there was no evidence that it had entered/blocked the hole. The tire went flat relatively quickly. He was alerted to a low tire by his TPMS system and by the time he had found a good place to pull over (about a mile), the tire was completely deflated.
As for it geling......it does to a certain extent but will still "flow" to the bottom of the tire when left sitting. It is more liquid than gel. It takes a mile or so for the "lumpiness" to go away when you first start out as it is redistributed around the circumference.
So, based on my own experience, I don't use it anymore. It is costly and seems unreliable (at least in my experience). I just carry plugs and a small compressor.
I too carry a tire repair kit and a compact compressor. One of the reasons for a bike with luggage.
How many flat have you had over all your years of riding?
And how many of those have been at convenient times and places? It's just not the same thing for everybody. So Ride-On has failed for someone. Plugs have failed for someone else. Some people prefer beads to Ride-On for balancing both of which offer dynamic balancing while weights only offer static balancing as long as they stay on the rim. Some people have never lost wheel weights while others have. At least one person here doesn't even use weights or goo.
This here's the Duck annit looks like we got ourselves an oil thread!
So do lead weights on the wheel, at minimal cost. It all depends on who chooses to spend their money wisely, or not.
I don't agree with the wisely/unwisely conclusion. It infers that one person's analysis gives the same answer as everybody else's. I feel strongly both ways. I used it for years and had good results with it. I changed a worn tire once with a puncture in it that I didn't know was there. But as a pensioner, I don't use it any more strictly because of cost/benefit. When I was working, I just spent the money and said "so what, it might help". Now I have to think about it more. An extra $34 at each change is no longer insignificant to me. Financially, it reminds me of back when I had to buy tires and tubes. Except for one front flat, every flat I've had in 50 years has been on the rear tire. All but one of those was gradual air loss. Since all I run now is tubeless tires, the repair has usually been quick and painless. I normally carry a compressor, gummy worms, and a Stop-n-Go kit. On desolate trips away from civilization I add a couple of large CO2 cartridges; internal patches; an emergency use tube; and tire tools. I had to use the internal patches once when a sharp wide shale stone put a rip in my rear tire on the Dempster Highway. Ride-on would not have had a chance on that. It took an internal patch to fix it.
Explaining the picture, the extra tire on the rear was my worn Metzeler 880. I had a guy in Dawson City get me a new rear tire for the trip up the Dempster and he changed it on his automatic changer. The only new tire he could get me quickly was a Harley-Davidson branded Dunlop D402. In the 900 miles of the round trip, the new Harley Dunlop experienced four flats. Several of them took multiple gummy worms side-by-side to fix. I had this flat about 60 miles from the end of the journey and it was too severe for gummy worms. I decided I was not man enough to put the M880 back on roadside, so I demounted the D402 and put in an internal patch. If I didn't have a couple of 68 gram CO2 cartridges, I doubt I could have reseated the bead. I could have used my emergency tube, which would have eliminated the reseating worry, but I decided to try this first. When I got back to Dawson City I had the worn-out Metzeler 880 reinstalled and tossed the nearly new D402. I rode the worn-out M880 over the Top of the World Highway into Tok and then down to Anchorage for a new M880.
I guess what I"m saying is that I have found Ride-on to be helpful but expensive in casual use. I find that it does what it says it will do, but it is no guarantee. Of course there are times when it does not work, and their commercials don't show the times when it doesn't work. I absolutely would not rely on it in desolate rides. In fact, without knowing for sure, I harbor a suspicion that its use may interfere with the bonding of a gummy worm repair in the event that the Ride-on proved insufficient. In this particular remote case, it took an internal repair. For casual rides in populated areas I now balance my tires with weights, and carry a normal flat repair kit plus a AAA Motorcycle towing card.
Everyone has a different pattern of use; different financial realities; and they make their own cost/benefit analysis coming up with an answer that is right for them. For me, it used to be right and now it is not. Same person, same product, same performance, but a different conclusion because my personal needs and limitations changed.
As the famous philosopher Popeye says...
"Ya pays ya nickel, and ya takes ya choice."
But did you find any glass or nail or screw embedded in the tire that the goop saved you from? If not, then there is nothing to give credit to this product for.
Seriously all you believers and even non believers like me - How many flats have you had over all your years of riding? I've had one in over 400,000 km. of riding over the last 50 or so years and that was plugged and re-inflated in 30 minutes with the kit I carry.
Piece of rock from gravel road on Alaska hwy that pierced thru tire, removed and no air leak, so proof ride on works...
In this age of fake news, a picture of the piece of rock, once removed to confirm its size, would be appropriate. Also, any residue of the goop on the rock, or extruding from the hole would be more positive proof.
EDIT: However, the question isn't whether it works or not. The point is, it is an unnecessary expense for the low probabilities of actually getting a puncture, which is often easily repaired with a plug kit anyway, a one time expense for the kit. Any other puncture, as in a major blowout or near sidewall puncture won't be helped by plugs or any Ride on like product.
  • Like
Reactions: T_C
Bush, you need a life..........
I have personally witnessed a tire, which I had put Ride-On in, get a small puncture, in the middle of the tread and the tire went flat...
In the interests of making this equivalent to an oil thread, I'll share my own experiences. Mine are with a similar product, Slime. But the principle is the same.
I used Slime in a tire that over the 14,000 miles of life, received at least four punctures. It always worked. There was one occasion when I took out a fairly large nail and the air was coming out and not stopping, so I merely rotated the tire to put the puncture at the 6 o'clock position. A couple tablespoons of Slime came out and the tire quit leaking air.
On a later tire, the Slime didn't work at all. I had put it in prophylactically. I was on the freeway and apparently ran over a roofing nail that went in and out quickly. By the time I could get stopped, all the Slime had flung out on the underside of the wheel area. Considering the size of the puncture and the speed at which the tire was rotating, I'm not surprised at all.
I think if I had been able to get another bottle of Slime to refill the tire and do what I did above to rotate the tire to put the puncture at the bottom of the tire, it would've worked. So I don't think Slime or Ride-On is a good idea to put in before getting a puncture. But I do believe it works when you give it a chance.
I carry a Stop-N-Go tire plug kit with me all the time, and bring along a Slime SPAIR kit on trips. Between those, I should be able to fix a flat for myself or someone else, if needed.
Well the wife's Prius got a flat yesterday. I found the hole and put some Slime in the tire. It's holding air now.
Toyota no longer puts a spare tire in the Prius, but uses their own version of Ride-On. If it didn't work, I doubt they would risk their reputation by using it.
If it does work, why did you have to add more?
  • Like
Reactions: T_C
If Toyota believes in it then it's good enough for me. :)
