The current wing has a seat height noticeably lower than my lowered ST. I was surprised.
You quoted the correct part of my post "to reduce the travel". That is what spacers or longer top-out springs will accomplish, where I would define travel as the full range of fork movement from topped out to fully compressed. The spacers also "shorten the fork" which is what the PO was seeking.
Reducing the preload on the main spring or changing the spring length will change the ride height. It depends what you want to achieve. Just putting softer or shorter springs will change the ride height but would not be my choice for control as there will be a point after an extension (e.g. riding across a dip) where the fork will be in free-fall with little or no spring to absorb chassis energy. Using a top-out spacer keeps the fork under control throughout the full range of movement, and allows the use of a correct spring rate to keep the static ride height at around 1/3-1/4 of the full travel.
If I read correctly the OP had already lowered the bike by an inch and was looking for lots more. Normal preload for a straight-rate spring would be around 15mm, so to lower the fork by 3 times that would mean running a spacer 30mm shorter than the gap between the spring and the fork cap. If you have a preload spacer that puts no tension on the spring then unless the spring rate is significantly increased you would run the risk of excessive bottoming under load because the spring would be significantly less compressed than normal at the point the fork tube hits the bottoming stops. In my view you are better off keeping or slightly increasing the spring rate, and limiting the full extension of the fork with changes to the top-out limits. This keeps the fork sitting at the preferred sag range to deal with dips while keeping the wheel in contact with the road at all times.
Dig out the old platform shoes !Just get thicker boots?![]()
I spoke to the nice folks at Traxxion, and they could do the job for $500. I'm not sure what all that includes. The problem is that I would have to separate the forks from the bike and ship to them, or take the bike to Atlanta.
I have a pretty good independent mechanic locally who used to work for a dealer.
RobbieAG said:If you're changing the whole geometry of the bike by lowering it
Lowering the front of the bike more that the rear would give me pause mainly because I don't know what I'm doing. This would make the bike handle quicker and twitchy to some riders. I've always thought this lessened higher-speed stability.
That was pretty much my intention (except cutting the spacer) until I ran into trouble disabling the anti-dive. Once I decided to send the forks in, it made sense to have them rebuilt because the bike has 57k miles on it and had original seals and bushings. They would probably need to be done before long anyway. Once I was there, it was only another $150 to have them revalved, so that's what I did.Robbie, I'd like to get some aftermarket straight springs, cut a spacer in each fork 1 inch, refill with standard fork oil and call it a day.
I could get Sonic middle of the road firmness springs, and not disable the and dive, not revalve, put standard 7.5 weight oil back in, and cut the spacers 1 inch.
In the schematic I clearly see spacer I could cut on one side, but the other is more difficult to see. Would I be able to cut/remove an inch of spacers on both sides based on your experience?
As I try to think this through, if I have the springs lowered 1 inch, wouldn't it be impossible to also push the fork tubes up in the triple trees 3/4 inch because the top of the fender would hit the bottom of the triple tree?
What am I missing?
If I lower the forks internally by 1 inch by removing or shortening a spacer, can I still raise the forks in the TT, and if I can, by how much?
