First of all, I've never done a suspension fluid change before, and I found all of the advice and resources here very helpful, especially the Delboy's Garage video. Not to mention your tools, John. Thanks you for the loan of them!
As for the discoloration, that seemed to be all it was. The tubes are straight and smooth (except at the very top, but not so bad as to be overly concerned. Unfortunately I had no metal polish on hand, so I just went at them with the microfiber and then greased up the tops of the tubes with a swipe of silicone grease. It seemed to work out just fine.
I agree. Not to worry, Nelson. How long since the last suspension fluid change? What did the old stuff look like? Condition of the bushings?
I have no idea how long since the last change. I obtained the bike with approximately 33,000 miles on it, and I've added only about 900 miles since.
The old fluid smelled rancid, but I don't know if that's normal or not. The fluid in one fork was bluish/gray while the other was a deep dark gray.
The bushings actually appeared to be in good condition, but I changed them, just the same.
As of this moment, I haven't finished the job as I was pulled away from the work I started. The right fork is back together, but still needs the oil added. The left is almost back together and also still needs oil. I hope to complete the job tomorrow afternoon/evening.
I have bushings I could send you. Was taken out by the suspension tech when they changed them over from previous owner to me. Even tho they look new. OEM. Honda parts with very little miles.
I'd try to clean up the stain with brake cleaner. If the tube is smooth I would not worry about it.
Thanks, The Cheese, but I already ordered a set and have them in at this time. I truly appreciate the offer, though!
Brant; thanks for the suggestion. Although I haven't encountered any problems, I'll keep your suggestion in mind!
