I assure you I have already searched, and read many of the posts on this subject. I am not talking about the dangerous drag caused by the SMC. I have already changed the fluid ( I didn't introduce any air to the system, I used the 7 step bleeding method, and did a thorough job). I also removed the front calipers, pushed each piston out about .75" and thoroughly cleaned them. I also greased the pins, as well as the pins that go through the pads. Also cleaned/greased the guide slots the other side of the pads rest in. I basically made sure everything is moving free and easy with the calipers.
After all of this, I still get an annoying drag coming from the front at around town speeds. It is just that, an annoyance, nothing else.
I am just curious if this is just something normal we all have to put up with.
Thank you in advance !
