simple question ref washers to front wheel
KENT
should the front wheel of an aw 1998 abs st1100 have seperate washewrs fitted along the axle bolt.
When I took it off there were two washers, but putting it back together and refering to st1100 fiche it does not show these washers that came out. iy shows axle bolt through left fork, speed housing thing the wheel then a spacer then the other fork. thats it??
If washers are required where would they fit in that order of things please.
Rob
this picture might help. The only washers that it shows are inside the speedo drive housing. I'm not aware of any washers that you remove/replace
Capture.JPG.
KENT
Capture.JPG.
yes this what i was using thanks very much. ill leave the extra washers out.
