Sirbike made me do it
More of "while I'm at it" whackjobbery....
For years I ran this Yamaha FZ-1 manifold on the front brakes with Spieler lines I had made.
The thing about it, is that the bore on it is around 6.5mm. Seemed to be somewhat a pain to get to bleed right (air?) and I didnt like the feel on the lever, ok, but not great.
Well...dammit.. the brain goes off, I can do better than that... So, calipers out, and gyrations go on to design this... worked at it to make sure the
banjo bolts near bottom out for minimal space between the bore and banjo port and still get a seal....
Machined in the flesh.
Side by side...
Smaller bore... better?
So as above I was starting to mount it, a friend stops by and says.. ."You know, that would look great anodized red" Me....oooooohhh, I didnt think of that.
Off to an anodizer... and get this....
Mounted up looks like..
later
Nice work indeed! If I had only one suggestion to assist bleeding, may be offset the inner 3.5mm hole to the top instead of through the middle?
Interesting idea, not sure how that would be machined... I do have a bleed banjo on the left side...
