Northern Dancer
Northern-Dancer
Some how ST1300 Police Special Model Year 2006 dropped 26,448 Kilometers on its Odometer Total and reset Trip Meter? I noticed this when taking a long Ride on May 23, 2017 with my GPS showing 503.5 Kilometers Traveled but my trip showing 316.8 Kilometers. I keep religious Records on my Motorcycles so I wonder what could have caused this?
So It took another Ride May 28, 2017 of 308.9 Kilometers by GPS but My Motorcycle Trip indicated 194.4 Kilometers with the Odometer accumulating an additional 194 Kilometers. The on board Fuel Computer indicated 18.4Km/L and the actual Fuel Calculation was 19.3KM/L or 54.36Mpg Canadian Gallon or 45.26Mpg USA Gallon. So the on board fuel Computer is fairly accurate and Speedometer agrees with GPS Speed Indication and everything else is normal so what can be causing this??
Would replacing the ECM (Engine Control Module) fix this problem and would that also reset my Odometer back to Zero? Also My ST1300 is a Police Special and has a Governor limiting my Speed at 120Mph and I want to bypass it or have it removed. If I replace the ECM with a Unit from a Standard ST1300 Model would it be compatible and achieve the results of fixing my odometer problem and removing this Governor?
Many Thanks
Northern Dancer
Many Thanks
Northern Dancer
